Ilikeurtractor
- Joined
- May 16, 2011
- Messages
- 1,069
- Tractor
- Iseki TX1300F/TX1500/ TX2160F/TS2220F/ Satoh S370D/S373D
Which one has the .5 ohms? The field or lamp coil?
I've had problems with the connectors too. They get brittle and break over time and can cause shorts and opens in the circuits. New replacements are out there. Since we've checked some things on the regulator and that isn't yielding an obvious cause let's go back to the charge light. We know that shouldn't be on when the key is off. How about the horn - does it operate when the key is off? I'm trying to understand why the charge light has power when the key is off and the horn, water temp, and oil lights are connected to the the same terminal that normally supplies +V to the light. What two wires did you work on going back to your first post?
