According to the manual I have the fuel injection rate for a K3A at "smoke set" is given to be 20.5 mm^3/stroke (+/- 1mm^3). At "start set" it's 30 mm^3 (+/- 5mm^3).
I believe start set is the max rack travel set by the stopper lever. When starting at low RPM no flyweight movement the rack should be near max rich allowed. Smoke set is whatever travel the governor allows before the springs on the governor and stopper lever reach equilibrium of forces at the stated speed of 1300 RPM.
I put in a setscrew to adjust max rack travel externally. My K3A stopper lever was stamped with the number 10.
Difference in displacement between K3A and B is 8.6%, that manual states the smoke set and start set fuel difference is about the same. For a turbo start with the basic assumption double pressure (absolute) double fuel.
