HomesteadOC
New to me beaver S370D, serial number indicated 77 or early 78 model year. Seller said it just wouldnt start one day, thinks glow plugs are bad. Got the non-running special for $2500, came with a front loader and theres little to no rust anywhere, fluids all look good. Got it home, ignition switch looks like its not for a diesel, glow plugs were wired to ignition on so they probably fried themselves running hot the whole time. Tested the circuit and I get 12v there, but plugs dont get hot, let alone warm. Ordered new correct switch, glow plugs, all the filters and fluids. Compression is at 275psi for #1, 300psi for #2, I put some lucas oil ATF cleaner in there the first day and then some high mileage ATF the second day. So far its been sitting for 2 days with the ATF cocktail in the cylinders. My hope is that the rings are stuck and this will loosen them up and return compression to something above where it needs to start at. If that doesnt work Im going to try some seafoam or restore. The mechanic Ive talked to on the phone says it looks like re-ringing is in my future. What results have you guys got from just a re-ring? Ive never worked on diesels before so Im not sure how great a job just a re-ring is going to do. I guess it all depends on how the cylinders are looking. I would just prefer not to buy the $900 build kit and pay for it to be bored and all that.
