ch85st
Member
Hi
Im having major problems with the hydraulics on a MT1601D
works fine for maybe 20 min after changing all Hydraulic oil, then suddenly nothing with hydraulics work cant lift 3point hitch cant lift Front loader, I have had the Hydraulic pump repaired as i thought it might be that, and i can see i have oil coming in from the pressure pipe in to the (Buck is it called that?) I have now disassembled the whole hydraulic head under the seat and cant figure out if its the control valve thats is the problem or its something else (besides that the control valve is from a MT180D from what i van tell)
perhaps the whole hydraulic system under the seat is from a MT180 D as it dont look like a MT1601D.
does anyone have a clue to what the problem could be? im leaning to that the control valve for some reason just lets oil pass thru with out ever building up any pressure.
Grateful for any help i can get as im not usually working with hydraulics
