Hello. I am looking for a 488 or 1465 NH Haybine just outside of Albany NY. Anybody know how much different the 488 and 1465 are. I cant seem to find any dealers close by that have both so I could check them out. Thanks!
The 488 and 1465 are both current model NH haybines, the 492 is an old model 1465.
The 488 uses a float that is only horizontal where the 1465 uses a lateral float system that allows the head to raise either side depending onthe ground conditions.
Thanks Art. Checked out a new 488 last weekend. Its a real nice machine. Especially when we are mowing with a 1971 NH 467 that has seen thousands of acres. The 1465 is about $3000 more than the 488. Got a liitle time to decide before cutting in June.
Decided on the 488 and bought it this week. It is in the shed now. I cant wait for June to try it out. The 1465 was a nice machine but cost $3000 more. I was kind of sad to see the old NH 467 haybine go, it has mowed 1000's of acres with minimal repair. But just the extra 2 feet is going to be a great time saver.
Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
What is the main difference between the 488 and 1465? From reading over the specs it appears the 1465 has a floating head, an extra bat on the reel, a couple hundred more pounds in weight and worth $3000 more. I will admit I don't have much knowledge of the current haybines since I switched to a discbine I haven't looked back but the main difference according to the specs is the floating head. I can't see that being a $3k option so Art or anyone can you please let me know more about the substancial differences between these two machines?
I will admit, I love running my discbine because of the speed but I miss the old 489 haybine. I don't miss fighting with it as the rubber had started coming off the roller so it kept wrapping hay up but it was fun to watch the reel move the hay into the cutter. The discbine is boring, you just drive and drive and don't have anything to look at. The hay goes under the shroud and leaves a trail behind Maybe I should mount a reel on my disbine
Is the gear drive suppose to be a better system? Given the price difference I am assuming so.
