what pump does it have if it is a cav which it should be. it should have a key way cut into the drive gear and on the pump shaft and u fine tune it with the three bolts where u bolt the pump to the timing cover. if it is a sims u have to set the pump flywheel on 18 degrees and line the to marks up on the front of the pump shaft and then bolt in it will either be in time or 180 degrees out and u fine tune the timing by the three bolts on front of the pump.
