Results 1 to 4 of 4
  1. #1
    Join Date
    Oct 2010
    Posts
    1,380
    NHtd75
    Default TD 75D Grease Question
    While having the front wheels/tires off for service it looks as if this would be a good opportunity to grease 3 points each side. The pic is left side looking forward at front wheel hub area. Fitting #1 is a tie rod end (for a lack of book terminology) and fitting #2 is the top of king pin (for a lack of book terminology). Also not visible and directly below #2 is a grease fitting for lower king pin bearing.
    If anyone has information about greasing these points (frequency and number of pumps) I'd appreciate if you would share that information. Also, would this be in the operator's manual?
    And while I'm here, the cap screws that hold these front wheels on appeared to have been installed dry. I'd appreciate any information from the book on that too.
    Thanks, SandburRanch
    Attached Thumbnails Attached Thumbnails TD 75D Grease Question-mvc-004f-jpg
  2. #2
    Elite Member Jerry/MT's Avatar
    Join Date
    Feb 2008
    Posts
    2,583
    Western Montana
    New Holland TD95D, Ford 4610 & Kubota M4500
    Default Re: TD 75D Grease Question
    Quote Originally Posted by SandburRanch View Post
    If anyone has information about greasing these points (frequency and number of pumps) I'd appreciate if you would share that information. Also, would this be in the operator's manual? And while I'm here, the cap screws that hold these front wheels on appeared to have been installed dry. I'd appreciate any information from the book on that too.
    I have a TD95D so, while not identical , it's pretty similar. My operator's manual is in the tractor so it's not handy. I never have seen any maintenance manual specify the number of pumps of grease to lube a grease fitting. I beleive the frequenncy is specified in the operator's manual. You can find copies of the operator's manual fairly cheap on ebay or you can get them from your local dealer. You should not be without that manual.
    Here's what I do, for whatever that's worth. If there is a rubber seal ( like on a greasable tie rod) I make sure the seal is inflated with grease but not so much that its' hard or leaks out. For non rubber sealed joints, I grease it slowly and until I see just a little bit of old grease start to come out. I just greased the entire tractor a few weekas ago at ~100 hrs.
    Rickb and Jbrink64 are NH techs and they might have some insight for you based on their experience.
    As far as wheel lug torque, that's based on the diameter of the lug bolt or stud.
  3. #3
    Veteran Member flyingcow's Avatar
    Join Date
    Jan 2010
    Posts
    1,086
    aroostook county maine
    Last post a good one. i will grease until i see grease coming out of fitting. Unless I see water ooozing out, than i pump the grease to it and flush the water out. Clean up with rag. Seeing a lot of water is a sign you need to grease more often
    TN75D, w/cab, FEL, BH
    7 1/2 ft Lucknow Blower
  4. #4
    Join Date
    Oct 2010
    Posts
    1,380
    NHtd75
    Quote Originally Posted by Jerry/MT View Post
    Here's what I do, for whatever that's worth. If there is a rubber seal ( like on a greasable tie rod) I make sure the seal is inflated with grease but not so much that its' hard or leaks out. For non rubber sealed joints, I grease it slowly and until I see just a little bit of old grease start to come out. .
    Worked good is what that's worth. The tractor is new to me but greasing those points isn't all that different than greasing any older piece of equipment.
    After two pumps I could feel the tie rod seal begin to pressure up and after 4 pumps the king pin bearings oozed out in a location it looked as if it was made to do so.
Similar Threads
  1. Still confused about grease (Kubuota 2320, FEL, MMM)
    By BK1 in forum Oil, Fuel & Lubricants
    Last Post: 02-25-2010, 11:34 AM
  2. I never use a grease gun: question
    By Fredartic in forum Parts/Repairs
    Last Post: 07-16-2008, 11:56 AM
  3. Grease Question
    By Larry_Davis in forum Kubota Owning/Operating
    Last Post: 02-17-2006, 02:13 AM
  4. Question regarding lubrication of bx2230
    By pjwbx2230 in forum Kubota Owning/Operating
    Last Post: 01-04-2006, 06:30 PM
  5. BX Question.. What type grease?????
    By Junkman in forum Kubota Owning/Operating
    Last Post: 05-15-2004, 01:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
