Page 4 of 4 FirstFirst 1234
Results 31 to 38 of 38
  1. #31
    Gold Member Hematite's Avatar
    Join Date
    May 2009
    Posts
    460
    Dutchess Cty, New York
    Default Re: What oil filter? I'm so confused.
    Quote Originally Posted by 90cummins View Post
    I'm doing a full service on a Ford 2120 replacing all fluids & filters.
    The only place other than the OEM that has the correct listings for this tractor or any other off road equipment is NAPA which carries Wix.
    The Wix on-line application catalog lists 2 primary engine oil filters and 1 heavy duty version.
    All these Wix filters have a 3/4-16 threaded base.
    51348 is the short version rated at 21 microns.
    51329 is the long version rated at 32 microns.
    A footnote lists the 57515 at 12 microns and for Various HD Equipment as a Glass media version of 51515.
    The 51515 filter platform at one time had the most Gas, diesel & lube applications of any filter.
    It fit all Ford autos & trucks and many small & large gas & diesel engines including Perkins & kubota.
    The criterion for selecting the correct filter is;
    Size to fit application,
    Base & thread size, will it fit and seal?
    Flow in GPM,
    Micron rating,
    Dirt holding capacity,
    Does it have an internal bypass? If so the bypass setting in PSI,
    Burst pressure.
    Expected service life in hours or miles.
    No doubt it is easier & safer to go to the OEM (maybe?)
    As was said the OEM changes vendors, part numbers & pricing.
    The OEM (ford) does not make their own filters.
    I would trust Wix for consistent quality & application data. They will also stand behind their filters & pay for damage caused by a defective filter.
    Try to get an OEM to do that!
    Many times the OEM won't warranty a legit mechanical claim!
    Use the link below and go to the Wix application website. Find the correct filters for your machines.
    WIX Filters : Filter Look-Up
    For even more information go to BOB is the OIL GUY
    - Bob is the Oil Guy
    I've said enough!
    You really didn't read post number 15 did you?
    2003 Massey Ferguson 2925, 25hp Hydro, 60" shaft drive mower deck, 60" manual blade, 47" shaft drive two stage snow blower.
    2008 New Holland T2310 Deluxe 40hp FWD Boomer, Dual power hydro/ 250TL FEL/ 758C BH/ 105A HD 72" gear tiller, Woods GB72 box scraper, Arrow Material Handling Mighty Max 48" pallet forks.
  2. #32
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,659
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Many here don't read full thread posts.. they just read the original one.. jump to t he end and make a reply..
    soundguy
  3. #33
    Super Member tcreeley's Avatar
    Join Date
    Feb 2011
    Posts
    7,766
    Hudson, Maine
    2003 NH TC30
    So is there the right oil to use...I posted earlier this year that the NH dealer told me I didn't need to buy the expensive 134 hydraulic fluid. He pointed to a cheaper priced oil and I asked what the difference was and he said it was the additives that absorbed condensation moisture. The he said that his customers (bigger tractors than my TC30) always bought the cheaped and throwin in a bottle of drygas. He showed me which particular brand and I bought it and the cheaper hydraulic oil. I put it in and have had no problems.
    But I always second guess myself. What do you do when the dealer suggests a cheaper way?!
    NH TC30, 7308 loader, 7' snowbear plow, 5' hiller, 5' tillovator (agrisupply), International Agritech 5' towable Bushhog. dumping carryhall, camo brush trailer, 8 hp Trencherman backhoe, International disk harrow, International single plow, Sears ZTL 7000, 8hp Roto Hoe Shredder'nChipper, CubCadet 524 snow blower, CubCadet rear tine tiller, working forge
  4. #34
    Join Date
    Mar 2002
    Posts
    52,659
    Central florida
    i run an oil meeting the M2C134 specs inmy ford and NH tractors. been doing it for a while... if I was still in warranty.. I might chip for the name brand oil.. etc..
    soundguy
  5. #35
    Join Date
    Jan 2012
    Posts
    168
    Long 360
    I just bought some UTF from TSC. They had 3,
    yellow bucket Xtreme on sale 29 from 31 met 134 a,b.
    Regular Travelers 44.50 134a,b,c,d and
    Travelers "Renew" 49.00 134 a,b,c,d for older tractors, stuff for seals etc.
    Since mine is 40 years old.
    I could have driven 15 more miles for a different brand( i forget ) yellow bucket for 37.00 134 d, so what is the difference?
    I know this is cheap oil and have used it with trans tune to help flush out water.
    Dont know about drygas??
    Filters are a ballancing act. Cant make too big a change.
    But stay away from the cheap brands and Fram.
    Dont quote me on this, but i think its like batterys, a very few companys make them all and put everybodys name on them built to there specs.
    Ds
  6. #36
    Join Date
    Mar 2002
    Posts
    52,659
    Central florida
    sae same as everybody else..
    for a flush oil I'd surely use the 29$ utf.
    heck.. for an old tractor, it likely meets your needs with 134 abc rating as it is..
    soundguy
  7. #37
    New Member
    Join Date
    Feb 2010
    Posts
    11
    Take a look at the Donaldson P550008
  8. #38
    Veteran Member sparc's Avatar
    Join Date
    Oct 2011
    Posts
    1,086
    NJ
    JD 4410, NH TC-25, Bobcat M610, JD X534, Dig-It Model 158, JD Ztrak 737. 6X4 Gator
    There was a comment made in this thread by someone, and it does not matter who, about the drainback feature that some filters have and some don't and how they did not think it was a big deal. But to me having the anti-drainback feature would seem to be important as it helps keep oil up closer to the wear points and bearings so when you start up there is less lag in getting oil where its needed most. Without the anti-drainback every time you start up its like starting after an oil change and you have to wait for all the oil to get pumped out of the pan. Those seconds add up over time. If the original equipment filter had a anti-drainback then I think it should be in any replacement filter.
    Same goes for oil filter bypass pressures. The design engineers spec'd a filter with a certain bypass pressure right? Must be a reason so why would you arbitrarily jump from 8 to 20 psi? If the filter media was plugged then every time you start up pressure has to build to >20 psi before it flows through the filter (without being filtered don't forget). Maybe moving to a lower pressure (20 down to 8 for example) would not be detrimental but increasing the bypass pressure can't be good.
Similar Threads
  1. Kioti Filter and Manuals plus Dealer Recommendation for Parts
    By LeTempt in forum Kioti Owning/Operating
    Last Post: 08-25-2015, 11:14 AM
  2. Hows this for new oil discussion
    By neucam in forum Oil, Fuel & Lubricants
    Last Post: 12-12-2008, 11:51 PM
  3. Is Amsoil API certified?
    By saparks10 in forum Oil, Fuel & Lubricants
    Last Post: 10-02-2007, 07:31 PM
  4. 2007 Chef of the Year Southest & Olive Oil
    By rox in forum Family and Friends (Announcements & Notices)
    Last Post: 07-30-2007, 03:21 PM
  5. Oil & Fuel Chnage oil, leave filter unchanged
    By Doc_Bob in forum Owning/Operating
    Last Post: 10-24-2006, 05:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
