AV8R737
Hi folks, I am brand new to the forums and not much experience with tractors, so I look forward to using your knowledge and experience... I have an early 70's F3000, diesel. 2 questions to start with:
1. The RH power steering cylinder is leaking in the front. Is this repairable, can I change seals, o rings etc... to fix the leaks or do I have to replace the whole thing?
2. I have a "fluid" leak from the cover plate where the clutch pedal arm enters into the body of the tractor. Any ideas on how to stop the leak- do I need to change a gasket/snugging the bolts did not do the trick?
