Results 1 to 3 of 3
  1. #1
    Silver Member 2006gmcdmax's Avatar
    Join Date
    Aug 2012
    Posts
    173
    Augusta, GA
    Many but mostly ford diesels or ihc or jds
    Default Ford diesel cam bearing question
    Rebuilding my motor tonight and the crank bearig closest to the front of the motor has two holes and behind those two holes which are oil holes the other 3 have the oil holes but the back has no hole in the block metal
    Hole closest to the front of motor
    2nd from the front the other two look exactly the same is this fine or are there supposed to be holes behind all four of them
  2. #2
    Veteran Member whodat526's Avatar
    Join Date
    Apr 2010
    Posts
    1,510
    deridder louisiana
    fords
    Default Re: Ford diesel cam bearing question
    somebody has installed the cam bearings wrong all of the bearing spaces in the block have a oil port and it has to be lined up the the bearing whole
  3. #3
    Join Date
    Aug 2012
    Posts
    173
    Augusta, GA
    That's what I thought but they were all lined up in order except those last three dang I'm never going to finish this tractor it's one thing after another
Similar Threads
  1. Ford 3000 diesel timing question
    By 2006gmcdmax in forum New Holland Ag Tractors
    Last Post: 10-01-2012, 09:14 PM
  2. Pilot Bearing And Release Bearing On A Ford 3000
    By Shepp in forum New Holland Owning/Operating
    Last Post: 09-16-2012, 11:34 PM
  3. question with part on fuel system of ford 2000 diesel
    By mark conway in forum Oil, Fuel & Lubricants
    Last Post: 05-21-2012, 10:15 AM
  4. kohler 25 v twin cam bearing repair . help / ideas
    By cv730s in forum Parts/Repairs
    Last Post: 11-12-2009, 05:03 PM
  5. Ford 3000 diesel- HP research question
    By Kaliburz in forum Ford Vintage Tractors
    Last Post: 12-29-2007, 02:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
