Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Oct 2012
    Posts
    1
    tamworth australia
    new holland tn75s
    Smile new holland 469 haybine
    leaving behind uncut plants. near new cutterbar. no damaged knife sections. Does any one what might be causing this ?
  2. #2
    Join Date
    Jun 2012
    Posts
    709
    Mt Crawford Va
    massey GC 2400 JD LA 145
    Default Re: new holland 469 haybine
    Check to see that the guards are up tight to the cutter bar, the cutter bar and guards make a row of "scissors" and if they are not together they don't cut.
  3. #3
    Veteran Member zzvyb6's Avatar
    Join Date
    Dec 2006
    Posts
    2,324
    michigan
    jd 1070
    Check the knife bushing at the wobble drive arm. If its worn out and the rubber isolator is gone, knife motion is lost. Also check the wobble drive belt tension. If its slipping, the knife will stall. It could also be binding up because a blade is colliding with a guard. Make sure all the knives are contained within the guards. Lastly, use a hammer to pound the hold-down clips into position. They should constrain the knives down to the ledger plates on the guards.
    Lay the cutter bar down on a nice flat surface (like a concrete floor). The tips of the guards should all be in a flat line. If a few are bent up or downward, slip a long pipe (5 - 6') over the guard tooth and bend them back into line. You are really bending the mower floor plate, not the guard.
    There is no "I" in team, but there is a "Me" if you want to jumble it up a bit...
Similar Threads
  1. Mowing 469 haybine
    By ghinnyhen51 in forum New Holland Owning/Operating
    Last Post: 09-01-2011, 08:26 PM
  2. 469 Haybine ??????
    By xcsp in forum Ag Tractors & Machinery
    Last Post: 07-06-2010, 10:03 AM
  3. New holland 469 haybine help
    By rusty022 in forum New Holland Owning/Operating
    Last Post: 11-22-2009, 08:10 AM
  4. 469 haybine ????????????
    Last Post: 08-24-2009, 12:33 PM
  5. wobble box for a new holland 469 haybine
    By rusty11 in forum New Holland Ag Tractors
    Last Post: 04-08-2009, 08:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
