Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Member Shepp's Avatar
    Join Date
    Aug 2012
    Posts
    42
    Toronto Ontario
    Ford 3000
    Default Ford 3000 hydraulic pump drain plug
    So I finally managed to get the new clutch in my tractor. The frightening thing was on initial try out it acted like it was still frozen, but it turned out it was just the clutch pedal wasn't pushing the clutch in far enough so I turned the clevis in about 18 turns and that did the job, Now I have to bleed the hydraulic pump to get the loader working and I cant get the drain plug on the hydraulic pump off. Looks like who ever owned the tractor before had troubles too because its already rounded. I was wondering if I can bleed the hydraulic pump some other way like disconnecting one of the hydraulic lines and turning the tractor over a few times too get the pump primed.
    Shepp
  2. #2
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,111
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: Ford 3000 hydraulic pump drain plug
    you can remove the plug under the seat in the 3x5 cover and accomplish near the same thing.. however removal of that plug so you can repalce it woudl be on my list.
    try filing flats in it for a wrench.. that or try turning it with a cold chissle.. or ind a large hex nut and lay over it, and weld it on.. and then turn it out.. the welding heat coupled with more wrench surface area usually does it if ont of the other tricks won't
    post back if it still gives you issues..
  3. #3
    Join Date
    Aug 2012
    Posts
    42
    Toronto Ontario
    Ford 3000
    Quote Originally Posted by Soundguy View Post
    Thanks Sound Guy. Not sure what you mean by 3x5 cover under the seat. There is a hydraulic hose there that runs to the hydraulic controls for the FEL.
  4. #4
    Join Date
    Mar 2002
    Posts
    42,111
    Central florida
    is it on a diverter valve?
    if so.. it will be open anyway..
    post a pic if you want ..
    normally, there is a 3x5 blank off plate under the seat and a plug in it.
    you can install a diverter or spool valve there to run external hyds.. ASC kill the 3pt and run pressure fromthe cover to an OC valve .. etvc..
  5. #5
    Join Date
    Aug 2012
    Posts
    42
    Toronto Ontario
    Ford 3000
    Ok I will have a look tomorrow. And post a pic. Right now it is pouring rain and I am sipping a glass of wine in my trailer posting on my Iphone. The hydraulic hose runs into a what was a plug under the seat .
  6. #6
    Join Date
    Mar 2002
    Posts
    42,111
    Central florida
    pretty common...
  7. #7
    Join Date
    Aug 2012
    Posts
    42
    Toronto Ontario
    Ford 3000
    Sorry. Lost internet for awhile. Reception isn't to good in the middle of the bush. I think I know what you mean by the diverter valve. It has a knob that you pull out to divert hydraulic pressure to the FEL. So I guess I just have to remove the line out out of this to bleed the pump?
  8. #8
    Join Date
    Aug 2012
    Posts
    42
    Toronto Ontario
    Ford 3000
    Ford 3000 hydraulic pump drain plug-2012-06-10-002.jpgClick image for larger version.
    Here is a couple of pics of the hydraulic setup under the seat.
    Shepp
  9. #9
    Join Date
    Aug 2012
    Posts
    42
    Toronto Ontario
    Ford 3000
  10. #10
    Join Date
    Aug 2012
    Posts
    42
    Toronto Ontario
    Ford 3000
    That did the trick. I pulled the hose off the diverter valve and cranked her until she was flowing oil. All back together now for winter. Thanks for all your help.
    Shep
Similar Threads
  1. Replies: 15
    Last Post: 03-07-2013, 08:30 PM
  2. Last one, Hydraulic Drain Plug
    By scott123456789 in forum Massey Ferguson Owning/Operating
    Last Post: 10-19-2012, 11:04 PM
  3. Hydraulic sump drain plug: where?
    By jcliburn in forum Chinese Tractors
    Last Post: 07-12-2010, 09:00 AM
  4. B7200 Hydraulic drain plug
    By Spina in forum Kubota Owning/Operating
    Last Post: 11-03-2005, 07:15 PM
  5. Hydraulic Drain Plug
    By Bob85355 in forum Yanmar
    Last Post: 01-07-2003, 04:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
