Results 1 to 4 of 4
01-09-2013, 05:09 PM #1
1500 tie rod end needed
4wd 1500
Anyone have a good source for tie rod ends? Right side broke and I'd like to replace both so it's good for another 31 years
01-10-2013, 07:31 AM #2
Re: 1500 tie rod end needed
It looks like the part # is SBA334800231 But you'd better check that number to be sure.
New Holland says it is still available but at $128 I would be tempted to look for another source.
Take your old one down to your local Napa or favorite parts store and ask them to try to match it up.
They can measure it and compare it to others in the book.
You would be surprised at how often you can find a generic tie rod end that will work.
Otherwise you could find one that matches the taper and weld it onto your tie rod.
I have done that several times with good results. A little grinding, a little bondo and some blue paint and you are good to go.
Photo is of a rear tie rod end that I welded onto my 3000 Ford.
New Holland SBA334800231 TIE-ROD
“What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do something about them”
Henry Ford
01-10-2013, 11:11 PM #3
Hey Dog, thanks for the reply. I did find a used one online for 28us, but will take it to the parts store and see if I can get lucky
02-22-2013, 06:55 PM #4
I did get one at the parts store. With some persuasion from a grinder and a welder it works fine. Thanks again Ultradog
Similar Threads
Track rod assembly (tie rod end)
By kevin3251 in forum New Holland Owning/OperatingReplies: 0Last Post: 12-10-2011, 06:32 PM -
mf 1240 tie rod measurements needed
By rstone in forum Massey Ferguson Owning/OperatingReplies: 0Last Post: 10-12-2011, 11:41 PM -
Broken fixed end steering cyl tie rod bolt
By gdmclnh in forum Parts/RepairsReplies: 3Last Post: 09-03-2008, 06:55 PM -
Tie rod end.
By sqidget in forum Kubota Owning/OperatingReplies: 1Last Post: 04-30-2008, 10:14 PM -
BX2200 Tie rod end
By JimC in forum Kubota Owning/OperatingReplies: 2Last Post: 07-22-2002, 09:39 PM
