Results 11 to 14 of 14
02-10-2013, 07:59 PM #11New Member
- Join Date
- Dec 2012
- Posts
- 13
- Location
- Pittsburg, Kansas
- Tractor
- Ford 3000, IH284
Re: Ford 3000 power steering reservoir overflowing
Yes, it actually works great except for spraying out the fluid.
02-11-2013, 09:29 AM #12Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,133
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
hmm... gonna need rickb and / or ultradog on this one. I don't mess with ps very much past maintenance.
now if you need a manual box rebuilt.. no problem..
02-11-2013, 10:12 PM #13New Member
- Join Date
- Dec 2012
- Posts
- 13
- Location
- Pittsburg, Kansas
- Tractor
- Ford 3000, IH284
Today, first thing I tried the power steering and again it was squirting fluid several feet in the air. I then tried it with the filter removed and it still worked and didn't squirt fluid. I then drained the Power Steering reservoir and cleaned it and put the filter back in and filled with fresh fluid. After this it worked and didn't squirt the fluid. I used the tractor for about 30 minutes and it worked fine. I'm not sure what made the difference, but I'm hoping this problem is in the past.
JD
02-12-2013, 08:05 AM #14Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,133
- Location
- Central florida
- Tractor
perhaps a bit of gunk was plugging somehting and bew free and was then cleaned out during the service?
Similar Threads
Where is the Power Steering Fulid Reservoir on a Ford 2810 Tractor?
By jfmccullar in forum Owning/OperatingReplies: 1Last Post: 09-04-2012, 04:51 PM -
Power steering for Ford 3000
By guildlady in forum New Holland Owning/OperatingReplies: 3Last Post: 07-23-2012, 11:38 PM -
Power Steering on Ford 3000-Help
By ddagenhart in forum HydraulicsReplies: 3Last Post: 08-09-2011, 11:51 AM -
ford 3000 power steering
By ehengle in forum Owning/OperatingReplies: 11Last Post: 07-14-2011, 03:16 PM -
Adding power steering to a Ford 3000?
By Matt in TN in forum New Holland Owning/OperatingReplies: 1Last Post: 05-12-2008, 06:14 PM
