Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Gold Member 2006gmcdmax's Avatar
    Join Date
    Aug 2012
    Posts
    285
    Augusta, GA
    Many but mostly ford diesels or ihc or jds
    Default 69 model ford 4000 hard starting
    My ford 4000 runs great cranks right up when it's warm uses no oil what so ever, but the tractor if you leave the fuel shut off in as in the run position it takes forever to start usually kills the battery, but if you pull it out an leave it out it'll crank right up the next day. what's my problem I've fixed every fuel leak in it even changed an injector? I've redone all the leaking on the injection pump top too
  2. #2
    Elite Member Jerry/MT's Avatar
    Join Date
    Feb 2008
    Posts
    2,584
    Western Montana
    New Holland TD95D, Ford 4610 & Kubota M4500
    Default Re: 69 model ford 4000 hard starting
    The only thing I can think of is that it is leaking back from the injectors and through the pump when the shut lever off isn't in the OFF position. There must be an air leak somewhere.
  3. #3
    Join Date
    Aug 2012
    Posts
    285
    Augusta, GA
    Do you think one of the injector lines would cause this or maybe one of the injectors isn't sealing completely I've put one injector in it because it was smoking at idle cleared up now its smoking again
  4. #4
    Join Date
    Aug 2012
    Posts
    285
    Augusta, GA
    I wonder if I should get new injector lines one is retarded and u have to force it when tightening its after market so it doesn't fit good
  5. #5
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    ay weeping around the injector lines?
    spray everything down with carb cleaner and let dry.. then after setting.. look for wet oily diesel seepage.
    do this ont he injector pump.. and hard lines as well.
  6. #6
    Join Date
    Aug 2012
    Posts
    285
    Augusta, GA
    I founds it it was the metering valve
  7. #7
    Join Date
    Aug 2012
    Posts
    285
    Augusta, GA
    Almost finished
  8. #8
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    man your shop had nice carpet!
  9. #9
    Super Member TomSeller's Avatar
    Join Date
    Jan 2013
    Posts
    8,694
    JD, Massey, Kubota, Case
    Default
    Quote Originally Posted by Soundguy View Post
    And real nice tool cabinets too.
  10. #10
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    very true!
Similar Threads
  1. Ford 4000 starting problem can you help??
    By alanmcc18 in forum Parts/Repairs
    Last Post: 07-31-2014, 09:22 AM
  2. Ford 4000 starting problem can you help??
    By alanmcc18 in forum Ford
    Last Post: 06-03-2013, 12:03 AM
  3. Starting issues with Ford SU 4000 Diesel
    By jrmouse in forum Parts/Repairs
    Last Post: 10-01-2012, 04:02 PM
  4. ford 4000 starting problems
    By hawg80 in forum Ford Vintage Tractors
    Last Post: 01-07-2011, 11:05 AM
  5. What model ford do I have? 4000?
    By Tractor_Troy in forum Ford Vintage Tractors
    Last Post: 05-15-2007, 03:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
