Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Jan 2013
    Posts
    4
    Sherrills Ford NC
    Farmall
    Default 4000 ford won't start
    My 4000 ford diesel dies like it ran out of fuel. It has fuel, turns over but will not start.
  2. #2
    Elite Member
    Join Date
    Sep 2010
    Posts
    4,100
    CANADA
    Many
    Default
    Is the fuel shut off? Air lock in the system. Did you try priming it.
    More info will help us narrow down the problem.
  3. #3
    New Member
    Join Date
    Apr 2012
    Posts
    2
    vanceboro nc
    1974 mf 135
    Default Re: 4000 ford won't start
    make sure it has enough fuel to run. check for air in the system if there is air in system it will have to be bleed #1 YOUR FUEL PICKUP PUMP SHOULD HAVE HAND PRIMER LEVER ON IT Goto your fuel injector pump and lossen 1 or both of the bleed screws then pump the hand pump untill only fuel comes out without air. tighten bleed screws next find #1CLYLINDER AND LOSSEN 5/8 PIPE NUT SLIGHTLY tHEN PROCEED TO START ENGINE WITH STARTER With in a few turns engine should start hitting and run Retighten line going to #1 cylinder as soon as engine begains to run if this is not problem check filters for water or stopped up also could injector pump going bad
  4. #4
    New Member
    Join Date
    Jan 2013
    Posts
    4
    Sherrills Ford NC
    Farmall
    It did it today and I haven't had a chance to reall try anything. I just looking for some help
  5. #5
    New Member
    Join Date
    Jan 2013
    Posts
    4
    Sherrills Ford NC
    Farmall
    Thanks. I'll try that and see what happens
  6. #6
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,766
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    anything?
  7. #7
    New Member
    Join Date
    Jan 2013
    Posts
    4
    Sherrills Ford NC
    Farmall
    The fuel line from the tank was clogged. There is trash in the tank. I blew it out with air and bleed everything and she started.
  8. #8
    Join Date
    Mar 2002
    Posts
    52,766
    Central florida
    good to hear!
Similar Threads
  1. Ford One Arm Loader 19-209 (711) & Ford 4000
    By rwacho in forum Ford Vintage Tractors
    Last Post: 08-08-2013, 09:32 AM
  2. '69 ford 4000
    By Varmint1 in forum Ford Vintage Tractors
    Last Post: 09-27-2012, 10:23 AM
  3. Is it a Ford 4000 or a Ford 871
    By Friar in forum Parts/Repairs
    Last Post: 04-25-2012, 09:14 AM
  4. Ford 4000 won't start in cold
    By DrPhil in forum New Holland Owning/Operating
    Last Post: 12-28-2010, 05:55 PM
  5. Ford 4000 ?????
    By BuzzyG in forum Buying/Pricing/Comparisons
    Last Post: 12-11-2009, 09:56 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
