Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Aug 2013
    Posts
    13
    Aiken, SC
    Ford 4610
    Default 2600 Wiring Issue
    I've had a gas 2600 for awhile now and decided that I wanted to fix all the wiring going to the instrument cluster. When I got it the oil pressure switch was working, but that was about it. I have now clean up all the existing wiring replacing where needed and have it all connected back in accordance with the wiring diagram. Now it appears everything is working. However, the lights work when the tractor is not running, but cut off when cranked up. Any ideas? The hot wire is running from the battery side of the starter solenoid through the ignition switch and to the light switch.
    Dave
  2. #2
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,577
    Lincoln County, NC need new avatar!
    Just a Scag
    Default Re: 2600 Wiring Issue
    The feed to the light switch is not switched.
    Spring is the season of optimism.
  3. #3
    New Member
    Join Date
    Aug 2013
    Posts
    13
    Aiken, SC
    Ford 4610
    Default
    Thanks Rick. Poor wording on my part. The hot wire shares a spade connector on the switch, but the light switch is not powered through the ignition switch. Also, I went out this evening and took another look at it and the light is on when the tractor is running but it is very faint. Bad connection, bad switch?
    Thanks
Similar Threads
  1. Anyone KNow? Wiring harness issue
    By Mickey_Fx in forum Cub Cadet L&G
    Last Post: 02-04-2014, 12:18 PM
  2. Wiring Issue
    By Bamaboy1 in forum Parts/Repairs
    Last Post: 01-09-2014, 08:54 AM
  3. Wiring Issue
    By Bamaboy1 in forum New Holland Owning/Operating
    Last Post: 01-07-2014, 11:59 AM
  4. Trailer Wiring Issue
    By VortecZ71 in forum Trailers & Transportation
    Last Post: 11-26-2011, 06:29 PM
  5. LT2180 Wiring issue
    By magicalj in forum Cub Cadet Tractors
    Last Post: 05-31-2006, 09:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
