JD40MO77
Just wondering if anyone has any suggestions on where to buy a new clutch kit for a 73 Ford 4000 3 cyl. diesel with the 4 spd with Hi and Lo.
It has the 11" disc with 10 spline 1" hud and presure plate with the 29 spline 1 7/8" hub.
Also is there any setup required on the pressure plate? The orig. has England stamped it it so I am thinking it has never been replaced. It has a bunch of coil springs and there appears to be some sort of adjustment on each of the 4 fingers the throwout bearing rides against?
It shelled off one side of the friction material..........which may explain the strange thing that happened in the last coupla hours I used it. I am using it to pull a Durabilt DP60 dirt pan and have been loading it up with a 580K case backhoe so I can carry the most dirt per trip. I dumped a load and went off the steep incline next to the retaining wall at the walkout end of our basement and tried to let it coast before I grabbed Hi gear for the empty trip back down to my borrow pit/pond....... then it would release it just kept wanting to go even with the clutch pedal fully depressed. I guess the lining pieces got stacked up were pulling until the got slung out and it began to work "normally" again. Then after a few more trips it began to slip and I had to head for the shop.
I split it today and have to get an order in ASAP so I can try to get some more dirt up the hill.
I mainly am wondering about these rigid discs versus the spring dampened ones like the original. Has anyone had experiences that would make them stay away from the rigid ones??
