Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
  1. #11
    Platinum Member sawtooth's Avatar
    Join Date
    Sep 2007
    Posts
    902
    Default Re: Ford 5610 rear stabilizer bar help
    Can you send me a pic of them installed on your tractor? Just canít picture how they hook up. Thanks
  2. #12
    Super Star Member ovrszd's Avatar
    Join Date
    May 2006
    Posts
    16,759
    Missouri
    Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
    You bet. I'm on my phone. In mornin I'll get on shop computer an attach what I can find. Remind me if I forget...
    Richard
    "Happiness isn't having everything you want, it's wanting everything you have."
  3. #13
    Join Date
    Sep 2007
    Posts
    902
    Iím a little gun shy as the first set I ordered for my 4610 would not work. If I remember correctly the bolt/pin diameter was too small where it connects to the lift arms. To make it work I was going to need to switch lift arms or drill existing ones out but was worried that might compromise the arm strength.
  4. #14
    Join Date
    May 2014
    Posts
    840
    Paarl South Africa
    stibalizerchain runs from the outside (not inside) to the arms and sould have its anckerpoint inline with the lowerpoint attach to the tractor. Yours will brake when impl is atached.
  5. #15
    Join Date
    May 2014
    Posts
    840
    Paarl South Africa
    Ford 5610 rear stabilizer bar help-20180214_102956-jpg
  6. #16
    Join Date
    May 2006
    Posts
    16,759
    Missouri
    I've got hundreds of pics of my tractor but can only find one that include the stabilizers. I'm going to the farm where it's parked today. I'll get better pics.
    My stabilizers came with brackets that U-bolted to the axle housing outside the fender/ROPs brackets. Then bolted to the lift arms. I don't recall having to drill my arms.
    Here's a pic that barely shows the axle end.
    Ford 5610 rear stabilizer bar help-20170105_092810-1280x720-jpg
    Richard
  7. #17
    Join Date
    May 2014
    Posts
    840
    Paarl South Africa
    remove that chain
  8. #18
    Join Date
    May 2014
    Posts
    840
    Paarl South Africa
    Ford 5610 rear stabilizer bar help-20180214_205746-jpg
  9. #19
    Join Date
    May 2006
    Posts
    16,759
    Missouri
    Here's a couple pics of mine.
    Ford 5610 rear stabilizer bar help-20180214_094055-1024x576-jpg
    Ford 5610 rear stabilizer bar help-20180214_094104-1024x576-jpg
    Richard
  10. #20
    Join Date
    May 2006
    Posts
    16,759
    Missouri
    Quote Originally Posted by DLTTrekkers View Post
    remove that chain
    When I bought my tractor that's the exact setup it had. Installed at the factory.
    I switched so I had better adjustability.
    Richard
Similar Threads
  1. 5610 Ford rear axle seal replacement
    By Rmart30 in forum Parts/Repairs
    Last Post: 11-13-2016, 07:07 AM
  2. 3-Point Hitch Which stabilizer bar?
    By petebert in forum New Holland Owning/Operating
    Last Post: 07-08-2016, 11:56 PM
  3. Which stabilizer bar?
    By petebert in forum Attachments
    Last Post: 06-03-2016, 12:04 PM
  4. 91 Ford 5610 rear main seal help!
    By ggsvh in forum New Holland Owning/Operating
    Last Post: 08-22-2015, 02:27 PM
  5. Ford NAA Stabilizer Bar
    By Ortis in forum Ford Vintage Tractors
    Last Post: 07-20-2005, 05:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
