Where to get a Loader for a TN75
   / Where to get a Loader for a TN75 #11
I've not seen any local TN's with problems but they all are fitted with the ALO loaders here, have been as long as TN's have been out. I think the new NH loader is an ALO, not sure though.
   / Where to get a Loader for a TN75 #12
Well, I finally got my loader mounts fixed. Paid a welder to repair the wallowed out bolts (only the left side had an issue) that mount to the front casting (that the axle attaches to). He welded a grade 5 coupling nut into the lower hole (after hollowing it out more). I think I had it tapped out to a fine thread pitch 7/8 or 1 inch diameter hole (sorry, can't remember now). Anyhow, he re-tapped the upper hole to a coarse pitch thread and thought it would be good. I got the nuts and bolts at MSC (msc-direct.com). Great service, ok price. Delivery was $15 to my door on Monday, ordered on Friday at 5 pm.
Next I welded extensions forward to mounting pads located roughly under the radiator. I couldn't go straight forward due to the front wheel angle (caused by the articulation of the Supersteer).
Attached are pictures of the raw stock (1/2" x 5" bar stock), and a blank I made out of scrap wood. I ended up not following the bevel in the wood to increase the welded surface area. The other pics are various angles of the finished project. The loader mount is made of a combination of 1/2 inch and 1 inch material. I wanted to make the mount extensions out of 1 inch stock, but decided that 1/2 inch should be enough load sharing (besides, should I take the whole load up front, or should this be sharing the load?!). I didn't spend a lot of time purtying up the welds as I felt that some of the ugly was supportive. Used Offic-ial NH gray paint. Which doesn't match the original very well (nor did it on my wife's 1 year old LS125 minsteer).
Unless the repair fails, I am pretty happy with how it worked out. I did most of the work by myself (that #$%^%$!! mount is heavy), though at the final fitting (now the mount had two more bolts and had the extension on it) I had a buddy help me. I used a long arm floor jack to hold the mount up. I also had to weld a crack in the left mount in an area hidden by the cab (it was easy). The front casting is made of cast steel versus cast iron. The welder tried to show me how the sparks for one are orange, while the other was yellow. I couldn't see it.
I torqued the bolts to 325 or 350 pounds/foot. I think that the rating was for higher, but I didn't want to strip out the repaired bolt holes (yes, l am leary). That took two of us (not enough lead in my a**).
The only real concern I had along the way was when I jacked the cab up a bit to get to the bolts on the transmission.
So, keep those bolts torqued! Much easier that way!
   / Where to get a Loader for a TN75 #13
I have a 2003 Tn 75 with 647 hours on it and it has a bush hog m346 loader with bucket and round bale spear qiuck detach and I have not had any problems with the loader it has been on the tractor since it was new I think the loader was around $4900 I live in WV though don't know about price difference where you are from hope this helps a little bit
   / Where to get a Loader for a TN75 #14
Just a little tid bit of info on broken loader bolts. Not a fun problem. I have been in the loader business for 27 years "Time Flies When Your Having Fun"
Always keep your bolts and never use loctite. Try to take hardened bolts out of a casting after you have used loctite.
The best solution is to remove the paint between the parts being fastened together. Use Grade 8 bolts. Use Heavy Flatwashers only over slotted holes. Use a good quality "Crush" Washer or spring type Lockwasher. Torque The Bolt. I extreme cases Use "NORDLOCK" Lockwashers. Very expensive but very affective.
If Dirty Dusty is still looking for a loader visit the marketplace section of my website Stoll Loaders Built For Farmers Worldwide High-Tech Tractors
3 Point Attachment (A57454)
3 Point Attachment...
Sedan (A59231)
Sedan (A59231)
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
Basket Attachment (A57454)
Basket Attachment...
2003 GMC C7500 Utility Flatbed Truck (A56858)
2003 GMC C7500...
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
