Results 1 to 6 of 6
01-18-2012, 02:16 PM #1New Member
- Join Date
- Jan 2012
- Posts
- 6
- Tractor
- 1969 Ford 3000
1964 ford LCG 2000
Hello from a lurker,
Any idea of value of this 1964 ford LCG 2000
Issues per seller
It needs a battery box
carb work sometimes drips gas from air cleaner
new key ignition only works sometimes
some wiring for lights and stuff
a power steering pump its missing
L
01-18-2012 02:16 PM # ADS
01-20-2012, 08:37 PM #2Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,500
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Re: 1964 ford LCG 2000
ignition switch.. 10$
GOOD carb kit 35$
can of carb spray.. 5$
can of carb dip 20$
wire and lamp switch.. 20$
bat box + cost of angle iron and some 1/8 plate or a salvage or repro. figure 50$
ps repairs could set you back a good few hundred depending on what does or doesn't work in the system..
as is.. I'd have to say.. no more than 1500$ MAX.. and i personally wouldn't pay that either... plenty of better ones to be had at not much more money...
soundguy
01-21-2012, 10:27 AM #3Silver Member
- Join Date
- May 2005
- Posts
- 216
- Location
- SE Indiana
- Tractor
- Numerous
What transmission does it have?
The four speed transmission versions are worth least due to the absense of live PTO. $2000 max. Add a bit if it has a Sherman combination auxiliary transmission.
The Select-O Speed versions are much more versatile due to independent PTO and the availability of many more gear ratios. That said, many folks are afraid of the S-O-S transmission so they usually do not sell for any more than the four speed models.
In this market I would not spend more than $2000 for the tractor described even if it has a Sherman or S-O-S.
SDT
01-21-2012, 05:51 PM #4Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,500
- Location
- Central florida
- Tractor
quite obviously it has a 4 speed and some sort of sherman, from looking at the pics. shifter handle is visible in 1st pic, thus showing you it is a 4 or 5 speed. 2nd pic clenchis it with a sherman poked out on the left side, meaning it is for sure a 4spd. likely a combo, but NOT an OD only.
i have a 4000 RC 4 cyl gasser, factory WF, sherman combo.
soundguy
01-22-2012, 07:28 PM #5New Member
- Join Date
- Jan 2012
- Posts
- 6
- Tractor
- 1969 Ford 3000
Thanks Guys for all the input. I think I will pass on this one.
I have a lot of grass on hills to finish cut,I thought it Might be a bit safer with the wide stance but not looking to overpay.
Mike
01-23-2012, 09:18 AM #6Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,500
- Location
- Central florida
- Tractor
a lcg set wide WOULD be good for cutting on a hill.
and while a 4spd isn't awesome.. it is fine for hogging... IF it's priced correctly.
if that unit was/is dirt cheap.. go for it. if spendy.. pass on it..
Similar Threads
Ford 2000 - Buying decision ???
By brin in forum Buying/Pricing/ComparisonsReplies: 8Last Post: 11-24-2010, 03:43 PM -
Can i make my 2000 Ford lift higher?
By Jmalone in forum Parts/RepairsReplies: 24Last Post: 06-08-2010, 04:46 PM -
Ford 2000 distributor
By Oldstuff in forum Owning/OperatingReplies: 6Last Post: 06-08-2010, 03:19 PM -
64 Ford 2000
By onebadfish in forum New Holland Buying/PricingReplies: 7Last Post: 03-29-2009, 01:18 AM -
Oil & Fuel Ford Dexta 2000 with 3 cyl Gas?
By cjcocn in forum New Holland Owning/OperatingReplies: 14Last Post: 12-17-2007, 04:32 PM
