Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    47,306
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 1972 FORD 4000
    I agree. could be in for a pump.. colum rebuild. know it needs a pto shaft. will need a top cover kit.
    sounding more like a unit i'd buy for 1500$ at an auction and rip the maybee one good part out of it... the engine...
    Quote Originally Posted by RickB View Post
    I wouldn't call that often. Somebody else buying this wreck is no real loss. 2K was plenty before we knew about the bum steering box.
    souNdguy
    sent from my NOKIA LUMIA
  2. #22
    Elite Member
    Join Date
    Dec 2007
    Posts
    3,035
    texas
    7040 HDC 1153 fel
    that tractor is junk iron walk away from it and forget it.you can buy a good running 4000 for $4000 to $4500.and you would have close to $2000 more in that tractor to half way get it running.
  3. #23
    Silver Member bobsphotos's Avatar
    Join Date
    Apr 2007
    Posts
    142
    China, ME
    JD 3320
    Hello,
    This is an update. I did pass on the pile of junk iron at the dealer and finally pulled the trigger on a 1959 641 from a private owner. The tin is in sad shape but the motor starts and sounds great, PTO works, 3 PT hitch works and the tractor seems to be in nice shape mechanically. Thanks so much to all that chimed in on my original post.
    Now to my first few Ford questions. The fuel shut-off valve on the bottom of the tank leaks very bad so I am in the process of removing it to take a look at it. I have read online that this valve seems to be a chronic issue. I need suggestions on where to purchase parts like this and also suggestions on where to buy a user manual and shop manual.
    Thanks,
    Bob W
    -_mg_7805_e-jpg-_mg_7806_e-jpg
    JD 3320, 300CXFEL, Woods BH80-X Hoe with HYD thumb conversion, WR Long OBG2 48" grapple,
    Salsco 627 3PT Chipper, Timberwolf 3PT splitter,
    Fisher 7-1/2 FEL Plow, HTL, Front forks, landPride 6' rake
    Some of my Projects are here: http://www.acdseeonline.com/user/THE_REMDOG/
  4. #24
    Join Date
    Mar 2002
    Posts
    47,306
    Central florida
    if it is a screw in valve you can usually rebuild them with 2 orings. if it is a lever vlave, just replace it.
    If you don't feel like prying the stop rivit out of the old valve and putting an oring on the stem and then tapping hte small hole for a machine screw to provide a stop for the stem.. then replace the screw on unit too.
    Many of us fix them as the price is 25-60$ vs 25 cents of orings.
    I&T fo-20 shop manual covers general maint and service. if you want to rebuild the tranny or engine.. i'd get the more spendy ford shop manual. for all else.. the fo-20 suffices if you are slightly handy with a wrench.
    there are owners manuals online.. places like N Tractor Club
    Many parts can be had from sites like 301 Moved Permanently
    and many many parts are available thru a CNH dealer.
    sparex, A&I, tisco are the leading aftermarket makes of most of the parts.
    ignition parts can be had at napa and similar stores.
    Side-Mount Distributor:
    NAPA #CS749
    NAPA HEAVY DUTY PIERCED (ventilated) #CS753
    Standard Ignition #FD-8081
    Standard Ignition Blue Streak #FD-8081X (Premium)
    Condensor:
    NAPA #FA66
    Standard Ignition #FD-75
    Standard Ignition Blue Streak #FD75X (Premium)
    Rotor:
    NAPA #FA67
    Standard Ignition #FD-108
    Distributor Cap:
    NAPA #FA352
    Standard Ignition #FD-128
    6 volt coil IC7 ($48)
    6 volt coil IC7SB ($23)
    12 volt coil IC14SB ( 16$ )
    if it uses a spin on oil filter.. then motorcraft fl1-a fram ph8a, supertech st8anapa 1452 or 1515 etc.. or crosses will all fit. if it uses the canister oil fliter, napa 1004 of fran ch6pl fram or whatever crosses to them.
    I reccomend 15w40 C/S rated oil for the engine, and UTF fluid for the trans, hyds and rear end ( all seperate sumps...) though you could put 80w90 gl5 gear oil in trans and rear end and hydraulic fluid iso32 or utf in the hyds. Many tiems the seal inside between hyds and rear end leaks and hydro and rear fluid mix.. which is why i don't like plain iso type hyd oils, and do favor utf in all sumps.
    if any sumps are wet.. flush with diesel, atf and alcohol mix.
    souNdguy
  5. #25
    Veteran Member wmonroe's Avatar
    Join Date
    Nov 2005
    Posts
    1,966
    Southwestern, PA
    1958 Ford 961 Powermaster
    Default
    Those old fords are great tractors and if taken care of will last about forever. Soundguy, as you can see, is a wealth of information on these machines.
    Kubota L5240 with loader and backhoe
    1958 Ford 961 Powermaster LP
  6. #26
    Join Date
    Mar 2002
    Posts
    47,306
    Central florida
    Quote Originally Posted by wmonroe View Post
    my wife paraphrases that to say that i am 'full of it alright' sometimes.
    souNdguy
  7. #27
    Join Date
    Nov 2005
    Posts
    1,966
    Southwestern, PA
    Default
    Haha, my wife says the same about me.
  8. #28
    New Member
    Join Date
    May 2014
    Posts
    1
    new york´╝îNEW YORK STATE
    FORT 1300
    Hey I found a digital shop for ford shop manuals , here is the link : Vstars Files
    enjoy it!
Similar Threads
  1. 1972 FORD 4000
    By tractorowner13 in forum New Holland Owning/Operating
    Last Post: 08-09-2013, 02:17 PM
  2. 1972 Ford 4000 Stalls
    By mdh6677 in forum Parts/Repairs
    Last Post: 08-03-2013, 08:23 PM
  3. 1972 Ford 4000 3-Cyl Gas, Various Problem
    By newtraditionsfarm in forum New Holland Owning/Operating
    Last Post: 04-02-2012, 12:15 PM
  4. 1972 ford 4000
    By awnery in forum New Holland Owning/Operating
    Last Post: 03-27-2012, 09:26 PM
  5. hello from Va 1972 ford 3000
    By navydad80 in forum New Member Introductions
    Last Post: 10-10-2011, 06:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
