joes_427_vette
- Joined
- Aug 10, 2004
- Messages
- 1,268
- Location
- Midwest
- Tractor
- IH Cub Lo Boy, 955 John Deere , TC 55 DA New Holland, Bolens HT 20 and 1456
I just found your post today.
Yes, I looked at several different mounts and came up with a cross breed of my own design. I will try to dig up some pictures. It is constructed of 1/2" plate and 2 x 4 x 3/16 extensions to the front of the frame.
I didn't paint anything ( only primer ) because I wanted to test it out to see if there were any weak points to revisit. I'm happy to say it works beautiful and the 55DA provides enough flow at 1500 to operate the hydraulics. This spring in between seven other projects I will take the hoe off and give it some NH blue.
One thing I did try was lifting the rear axle up while digging and moving the machine forward without leaving the backhoe seat. It is solid as a rock. The 611 is overkill but works so well.Total cost of the mount in iron and bending the mounts was less than $250. with new steel.
