Results 1 to 10 of 10
  1. #1
    Join Date
    Jul 2007
    Posts
    57
    Eastern Tenn
    New Holland TC35
    Default TC35 FEL quick attach conversion??
    I just bought a 2002 TC35. While shopping around a lot of the new loaders offer a quick attach option. Can an older unit like mine be converted to this feature?
  2. #2
    Gold Member
    Join Date
    Jun 2006
    Posts
    330
    NW WA State
    1980 AC 5020
    Default Re: TC35 FEL quick attach conversion??
    Quote Originally Posted by navyjoe
    There are some manufacturers that sell "universal" quick attach parts that can be used to modify an existing loader. Some cutting and welding is required. Sorry, I don't have any links right now, I was looking at them several weeks ago, but I didn't save any links. Search for "skid steer" "quick attach", you'll find them.
    Monte
    2007 NH TC30 w/FEL, 6' box blade, 6' back blade, 6' Mott F6 flail mower, 6' chain harrow, 6' rock rake, Pat's Easy Change, looking for a 6' snow blower
  3. #3
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    You can buy a quick attach plate for your loader arms from NH for around $400 or less. The bucket will need the old brackets cut off and a new quick attach plate welded on. You can buy these plates on ebay or probably right from your NH dealer. The plate should be around $100. If it's a lot more, it's a ripoff. A welding shop can do the removal and weld-on for around $150. So expect to be out about $650 for the entire process. Well worth it...I don't know anything that I like better about my tractor than that QA loader.
    Jim
  4. #4
    Gold Member twabscs's Avatar
    Join Date
    Jul 2003
    Posts
    269
    NW Missouri
    NH TC40D, CaseIH Farmall 95, 105U
    Jinman is absolutely right. My pallet forks get much more use than my bucket and it's just 60 seconds to switch between them. Loaders should all come with QA standard.
    Tom
    '03 NH TC40D - TLB
    '08 CaseIH Farmall 95 - Cab/Loader
    '09 CaseIH Farmall 105U - Cab/Loader
    '05 CaseIH JX85 - Cab/Loader - Traded in for 105U
  5. #5
    Join Date
    Jul 2007
    Posts
    57
    Eastern Tenn
    New Holland TC35
    OK, thanks for the info from all. Thats what I needed.
    Joe
  6. #6
    Veteran Member mikim's Avatar
    Join Date
    Feb 2001
    Posts
    2,416
    Paige Texas
    NH TC45
    like this .. note the old brackets sitting on top .....cut them off then weld the QA plate on ... and buy the pin on adapter for the tractor side
    Attached Images Attached Images
    Mike
  7. #7
    Gold Member
    Join Date
    Jun 2006
    Posts
    330
    NW WA State
    1980 AC 5020
    Quote Originally Posted by mikim
    Where'd you get the parts?
    Monte
  8. #8
    Veteran Member 6sunset6's Avatar
    Join Date
    May 2007
    Posts
    1,028
    SE NY
    NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's, MF 30 TLB
    I paid $400 for the tractor end of a QA in 1999. I just priced a new TC34DA and the QA plate was $1027 for NH . I looked up QA about the same $1000.
    Really a lot of $$ for what they are.
    Bob H
    NH 2007 TC34DA 1985 MF30E Hoe
  9. #9
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Quote Originally Posted by 6sunset6
    The price of the QA plate on the loader arms used to be about $360. The bucket was about $600. Your $1000 price seems to be the plate and QA bucket. Are you sure just the adapter was that expensive?
    Jim
  10. #10
    Join Date
    Feb 2001
    Posts
    2,416
    Paige Texas
    NH TC45
    monte -- bought the tractor side of the QA from a dealer for about $400 ... the weld on plate I ordered from online for around $125...don't have that website for ya right now -- but do a search and you'll find 'em.....Best money I ever spent. Entire QA bucket was about $600 ....but then what do you do with the old one? Better choice for me was just to modify the old one.
    Mike
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
