Results 1 to 10 of 10
  1. #1
    Join Date
    Oct 2004
    Posts
    125
    Knoxville, TN
    NH TC29D
    Default TC29D Tilt Steering Broken? Easy Repair
    Well, after months of the tilt steering not working, I fixed it today and took pictures of it. I hope this helps others out there with it.
    First I had to remove the cover under the dash. Four screws in the engine compartment, and two in the front of the cover.
    Next, remove two allen head screws holding the tilt handle in place. Then loosen the nut holding the tilt handle and unscrew. Becareful, this is a small spring under it and a very small plastic washer.
    There is a small rod that pushes down to release the holding pressure. Mine was frozen, so I used a propane torch to heat the shaft a little and tap on it until it freed the rod. Then I oiled it and tapped on the small rod to work the oil down the shaft.
    Check out the pictures of the tilt rod.
    2003 NH TC29D Hydro 4x4, 914A 60" Belly Mower, 7308 FEL, 5' King Kutter Rotory Cutter, 60" Midwest Box Blade, Woods 7500 Backhoe. www.4x4TractorWork.com
  2. #2
    Join Date
    Oct 2004
    Posts
    125
    Knoxville, TN
    NH TC29D
    Default Re: TC29D Tilt Steering Broken? Easy Repair
    The tilt rod picture
    Attached Images Attached Images
  3. #3
    Join Date
    Oct 2004
    Posts
    125
    Knoxville, TN
    NH TC29D
    The top of the rod.
  4. #4
    Join Date
    Oct 2004
    Posts
    125
    Knoxville, TN
    NH TC29D
    The plastic washer.
  5. #5
    Join Date
    Oct 2004
    Posts
    125
    Knoxville, TN
    NH TC29D
    The spring.
  6. #6
    Join Date
    Oct 2004
    Posts
    125
    Knoxville, TN
    NH TC29D
    The adjusting handle.
  7. #7
    Join Date
    Oct 2004
    Posts
    125
    Knoxville, TN
    NH TC29D
    Tilt rod reinstalled back together.
  8. #8
    Join Date
    Oct 2004
    Posts
    125
    Knoxville, TN
    NH TC29D
    The plastic shield cover.
  9. #9
    Join Date
    Oct 2004
    Posts
    125
    Knoxville, TN
    NH TC29D
    The plastic shield installed back on the handle.
  10. #10
    Super Star Member
    Join Date
    Apr 2001
    Posts
    10,744
    NH TC25D
    Great explanation and pics! Something all we Class II owners will probably have to do sooner or later.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
