Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Bronze Member volunteer's Avatar
    Join Date
    Dec 2006
    Posts
    58
    Auburntown, TN
    1991 Ford New Holland 3930
    Default Hand or Foot Throttle Operation - PTO rpm's
    Thought I would ask the experts a question concerning my Ford -New Holland 3930 tractor. When bush hogging my 17 acres I have noticed that my 3930 does not stay at the 540 rpm indicator but slows down. In order to maintain the 540 rpm I have to manually increase the throttle. Is this normal or should the throttle stay at or very near the 540? Does this on flat land as well as hilly slopes. I probably understand why it would occur going up a slope but thought that flat land would be fairly consistent in terms of rpm.
    Thanks for any info.
    Attached Images Attached Images
  2. #2
    Platinum Member Grrrr's Avatar
    Join Date
    Jul 2007
    Posts
    800
    Devon, UK
    John Deere!
    Default Re: Hand or Foot Throttle Operation - PTO rpm's
    You will probably find that the rpm's will vary slightly as the stuff you are mowing changes. To a certain extent, the governor should adjust things to keep the rpm's the same. I tend to set the pto to 540 with the hand throttle at the beginning and then continue like that. If the rpm's drop a bit it doesn't really matter. If the engine starts to bog down then I step on the foot throttle till it gets easier again. I think what you are experiencing is normal.
    Jake
  3. #3
    Join Date
    Dec 2006
    Posts
    58
    Auburntown, TN
    That's good to hear. Appreciate it.
  4. #4
    Join Date
    Oct 2006
    Posts
    160
    The Southern Tier, NY
    F-NH 3930
    Huh. You know... I've got a 3930 and I've never noticed that. But then... I set the hand throttle and then just go. Depending on the terrain just going is anywhere from 2 low to 2 high (I've got the synchro shuttle and I'm using a 6' cutter). And I rarely look at the guage once I've set the throttle.
    I see you've got a 6' cutter. So... How fast are you going? I'm actually not looking for an answer so that I can point out what you're doing wrong - I'm just curious to know what other people do with this tractor! From a recent thread on chugging I've decided I'm not doing that and I could maybe even mow downhill in 3 high. If the terrain wasn't so darned bumpy!
    Wife, kids, house, car... Set! Tractor? Who needs a tractor? What would I do with one, anyway???
  5. #5
    Join Date
    Dec 2006
    Posts
    58
    Auburntown, TN
    On one large steep hill I am either in 1 or 2 low, usually 1. On another hill 2 or 3 low. Flat land 2 or 3 high. I'm still new at this so generally I'm going slow, learning exactly where all the rocks are. Just bought a new set of blades fo cutter, the kind that are curved for lifting up what is being cut. They sure bring a nice look to the cut but they sure can throw a mean rock.
  6. #6
    Join Date
    Oct 2006
    Posts
    160
    F-NH 3930
    Huh. Not 4 low? 'Cause you don't have one or other? I find it to be an awfully whiney gear!
  7. #7
    Join Date
    Sep 2005
    Posts
    1,192
    Ohio
    Case DX55, Ford 850
    It sounds like your thottle pressure plate needs to be tightened, or your spring is weak. That's what holds it in position when you adjust your throttle. You are overriding that when you hold pressure on your foot throttle.
  8. #8
    Join Date
    Dec 2006
    Posts
    58
    Auburntown, TN
    Thanks for the tip. I'll check the manuals and check it out. Appreciate it!
  9. #9
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,102
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    I agree with ford 850. I believe your 3930 has a hand throttle assembly similar to my 7610s.. And I had to tighten the nuts holding the friction disc.. or mine would slowly loose RPM as well.
    Soundguy
  10. #10
    Join Date
    Dec 2006
    Posts
    58
    Auburntown, TN
    Thanks for the info. I'm hoping this is minor mechanics as I'm new to this. I hate to admit it but this little Ford 3930 so far has been a great tractor. I now understand (in reading various posts) what a great time it is in getting seat time on the tractor.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
