BOOMHAUER
My PTO engagement lever has always worked like butter, throwing it in and out has never been a problem or thought. I have used my farmi winch this winter pulling out firewood. 2 weeks ago the lever started to get some resistance, I chaulked it up to sticky linkage that I needed to grease. Well, yesterday I go to pull out my last tree. I fired up the tractor let it warm up and drove up to the woodlot. The PTO lever was very stiff, it took considerable effort to get it to engage. Winched the tree out, then tried to disengage. Lever would not budge. I tellin' ya I bent the lever trying to get the PTO lever back to the off position. I knew at this point that if I turned the tractor off up in the woods, there would be no restarting. Drove it down to the barn, and used a pair of visegrips on the rod that enters the center transmission. This worked, albeit very stiff. Took the seat off, the levers apart, lubed everything, still stiff. The pics below show where the connecting rod enters the tractor center core. Whats up? Is there a clutch of some sort that engages/disengages?
