Results 1 to 3 of 3
  1. #1
    Join Date
    Sep 2004
    Posts
    85
    Upstate NY
    New Holland TC 30 HST
    Default TC-30 HST PTO Hard to engage
    Hi All,
    I have a 2004 TC-30 with 350 hrs and the PTO is getting harder to engage and disengage to the point I think Iam going to break the handle, it takes two hands now to yank this thing into gear. I have checked all the external linkages and oiled them best i can. It seems it is internal now..any Ideas out there, Thanks in advance.
    Chris
  2. #2
    Join Date
    Mar 2005
    Posts
    713
    NE Oklahoma
    Kioti ck30
    Default Re: TC-30 HST PTO Hard to engage
    This may sound dumb, but I had that problem engaging my 4x4. I asked Jon about it and his reply was squirt it with wd40. I'm thinking "you think I'm dumb? I already tried that."
    But.. I went out and did it again and worked it and worked it. Works just fine now. I guess the second time was a charm..
    Sooo, try to lube it some more. Who knows..
    Now then, stay tuned for answers from guys who really know the answer.
    NE Oklahoma, ck30 kioti BH w/thumb, Broken FEL, toothbar, box blade. JD 60" brush hog, home made forks
    My Photo's
  3. #3
    Veteran Member LarryD's Avatar
    Join Date
    Mar 2004
    Posts
    1,157
    Whidbey Island, WA.
    TC33D
    I use lithium grease from a spray can. It seems to last longer and lube better. When I first started having the same problem you describe it took several spray/work/spray/work cycles but soon it just slipped into position.
    Make welfare as hard to get as a building permit
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
