Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Jul 2008
    Posts
    1
    Default 7740 sle transmission
    we have ford/newholland 95 7740 sle 7500hrs up.it started to grind getting it into reverse, so i had a look a found that the lock nut was loose on adjuster top of transmission.adjusted it, to where it stop grinding (lovely), but it started to grind going into forward after a few times of normal operation! is this a problem with adjustment or faulty solenoids , there known to give trouble so i have been told,had to rewire earths ,a lot were bad connection and broken.any information would be greatfully apprieciated.
    thanks
    have no manuals or experience in this field !
  2. #2
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,537
    Lincoln County, NC need new avatar!
    Just a Scag
    Default Re: 7740 sle transmission
    No solenoids or earth connections involved here. You should try to fine tune the cable adjustment, but that may not be possible. Your Forward/Reverse synchronizer may be trashed. It requires a double split (transmission removal) to replace. The snchronizer was over $2000USD several years ago. The 1-4/5-8 synchronizer should be examined carefully, as it will be next to go. It would also be prudent to replace the piston seals and sealing rings in all 4 clutchpacks with those hours, given the transmission will be mostly disassembled. Just remembered there is a serial number break on that synchronizer, be careful when pricing/ordering parts.
  3. #3
    New Member
    Join Date
    Jul 2009
    Posts
    1
    looking for someone knowlegeable about these tractors have spent over 3000 usa dollars and still not working
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
