Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    New Member
    Join Date
    Dec 2004
    Posts
    11
    North Carolina
    ford 3000 diesel 1970
    Default Ford 3000 hydraulic lines
    Seals leaking at the rear of pressure and return hydraulic tubes by the brake arms, already have hydraulic pump off and replacing the pressure nut but noticed bad leak at end of tubes. I can't seem to find directions to remove these...any help would be helpful, Thank You for your time---ncmike
  2. #2
    Elite Member JC-jetro's Avatar
    Join Date
    Jul 2006
    Posts
    3,285
    Kansas
    Ford 1700, Kubota MX-4700
    Default Re: Ford 3000 hydraulic lines
    How about dome close up pics? That might provide some clues.
    JC,
    Ford 1700, 2wd.
    Kubota MX-4700DT, Gear transmission with LA 884 loader, Q/A and HD bucket.
    60" Woods Rotary Cutter, home made (3-pt boom and a Row Hipper) ,King Kutter( 5 ft Tiller,Middle Buster,Single Row Cultivator,Carry-all, 5 ft blade, 6 ft Landscaping Rake ,30" Dirt Scoop and a 4'x4' Drag Harrow)
  3. #3
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Exact connection will depend on tranny type.. here's an exploded diagram pic showing a couple different tubes/trans types and how they mount.
    soundguy
    Attached Thumbnails Attached Thumbnails Ford 3000 hydraulic lines-3000tube-gif
  4. #4
    New Member
    Join Date
    Dec 2004
    Posts
    11
    North Carolina
    thanks so much Soundguy...I think the tranny is the one on the bottom right in the pic but am away from home and am not 100% sure, will check in a few days...appreciate your expert advise and trying to help a rookie like me, might have to take a photo as JC-jetro
    suggested if I can figure out how to do that also...thanks again, ncmike
  5. #5
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    Good luck.
    soundguy
  6. #6
    New Member
    Join Date
    Apr 2014
    Posts
    7
    Johannesburg
    Massey fergussen
    Hi
    Do you have the hydraulic schemactics for a 1965 model? It simply wont work and the pump has got pressure, it just seems to circulate as an open circut with no pressure build up.
  7. #7
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    if it is circulating open circuit then I would say the pump has no pressure, but has flow!
    Pressure is the resistance to flow.
    Ina nay case, you can pull up all of the exploded parts diagrams for that machine at the NH parts site. I'm at work pulling a 14hr double and my 3000 shop manual is no where near me.
    That said.
    If you know it is open circuit flowing.. I'd look at the unloader valve and backpressure valve. if the unloader sticks in the 'unload' position.. oil circulates.
    if the backpressure dies and does not provide some low psi (40ish ) to the unloader.. the unloader won't operate.
    souNdguy
    sent from my NOKIA LUMIA
  8. #8
    New Member
    Join Date
    Apr 2014
    Posts
    7
    Johannesburg
    Massey fergussen
    Hi, thanks for the response, looked on net for about 3hrs yesterday + other days for exploded parts diagrams/hyd.
    schematics, this is the first positive lead. Have you a link to NH parts, as i'm in South Africa
  9. #9
    Gold Member Ultradog MN's Avatar
    Join Date
    Jun 2006
    Posts
    274
    Twin Cities, MN
    Ford 3000, Ford 4450, Ford 4200
    Quote Originally Posted by John Bull View Post
    New Holland - Choose your brand
    “What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do something about them”
    Henry Ford
  10. #10
    New Member
    Join Date
    Apr 2014
    Posts
    7
    Johannesburg
    Massey fergussen
    Hi Soundguy, battling to look it up on the NH website, would there be any possible way that i could get a scanned copy from you when you can get to your manual.
    I would really appreciate this, as the internet connection here is pretty slow and intermittent too.
    Thanks again.
    And thanks Ultradog for the link to the Website but not sure where to find the diagrams. can you send me a direct link to the page if you know where it is? i have looked but not getting much success.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
