nickel plate
My 2002 NH TC-40 has liquid filled rear 13.6-24 tires. My main concern is that I occasionally tow it 100 miles each way once or twice a month (50% mountain driving) and will hopefully soon be adding a Woods BH90-X backhoe and hydraulic thumb. The total package weight including the trailer, tractor with 1/2 tank of fuel and filled tires, FEL and backhoe will be about 12,300 lbs. The trailer alone can carry a little over 16,000 so I'm ok there, but my Ford F-250 diesel 4x4 TV is rated to tow up to 13,300 lbs. This only leaves me about 1000 lbs of margin.
How much does the fluid weigh in each of the rear tractor tires or how many gallons of fluid do they hold? Are they generally filled full or partial? Would there be a signifigant towing weight savings if I drain them?
When I use the 6' FEL I always have my Gearmore 6' scrapper box with 6 ripper teeth attached for counter balance. Do I still need the fluid filled tires for counter balance? Soil is not an issue so filled or unfilled tires will make no difference.
