Results 1 to 9 of 9
  1. #1
    New Member
    Join Date
    Mar 2009
    Posts
    1
    Default Ford Hydraulics on a 1700
    Need advice/info, I have a 1700 with loader. When 3 point control arms are 3/4 or more raised I get a hydraulic pressure noise that steadily increases the higher the control arms go. It also affects the operation of the loader if the control arms are up. At one point the loader locked itself in the highest position and would not come down until I lowered the control arms. This does not seem right that I cannot use the loader and 3 point to their 3/4-full extension at the same time. Anyone have experience with this?
  2. #2
    Elite Member JC-jetro's Avatar
    Join Date
    Jul 2006
    Posts
    2,850
    Kansas
    Ford 1700, Kubota MX-4700
    Default Re: Ford Hydraulics on a 1700
    Fire,
    welcome to TBN blue. I don't have a loader on my 1700 but what you are describing is the symptom of maladjustment of lift arm feed back control. It is set where you relieve pressure back to reservoir thru main safety relief. There are several thread about it in this forum. let us know if you need more help.
    JC,
    Ford 1700, 2wd.
    Kubota MX-4700DT, Gear transmission with LA 884 loader, Q/A and HD bucket.
    60" Woods Rotary Cutter, home made (3-pt boom and a Row Hipper) ,King Kutter( 5 ft Tiller,Middle Buster,Single Row Cultivator,Carry-all, 5 ft blade, 6 ft Landscaping Rake ,30" Dirt Scoop and a 4'x4' Drag Harrow)
  3. #3
    Veteran Member Hooked_on_HP's Avatar
    Join Date
    Dec 2005
    Posts
    1,998
    Coal City IL
    Ford 1900 FWD Kubota F2100E
    JC's info is correct.You need to adjust your position control link.This is the L shaped rod that conects from the lift arm to the feedback link. Also the saddle the lift lever sets in in the up position is adjustable. If you do a search I think JC posted the procedure for adjustment.
    Bill
  4. #4
    Join Date
    Jul 2006
    Posts
    2,850
    Kansas
    Fire,
    FYI as Bill suggested. Please look at the link below.
    JC
    http://www.tractorbynet.com/forums/h...ic-system.html
    Ford 1700, 2wd.
  5. #5
    Super Member JB4310's Avatar
    Join Date
    Feb 2005
    Posts
    5,645
    Central CT
    J.D. 4310 E-hydro
    Welome FIRE1388,
    Wow, we've got more and more 1700 owners here now.
    I've got to study that thread JC linked to, I know I was part of that discussion but I never did anything at the time to correct the noise I'm getting when my 3pt is near the top. Mines not that bad but it's a little annoying, I hope it's not hurting anything?
    My 3pt bleeds down very fast when engine is off, in half an hour or less it will bleed all the way down if there is a heavy load on it. I know bleed down is normal but wonder if being that fast is indicative of other problems with 3pt system?
    JB.
    JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 48", 61"HD & 73" high volume bucket.
    FORD 1700; 2 WD, 2600 hrs.
    JD 320; Hydra lift, 48" deck and 48" snow blade.
    2007 Dodge Ram 3500, Cummins 6.7L, Aisin 6 speed, 9ft utility body.
  6. #6
    Join Date
    Jul 2006
    Posts
    2,850
    Kansas
    Quote Originally Posted by JB4310 View Post
    Welome FIRE1388,
    JB.
    John,
    I'd say 9 out of 10 the bleed down is caused by lift cylinder seal/Oring partial failure. Maximum 1 hr of labor and $10 you'd get it fixed. Take a look at the link below and you should find all you need. I pre-warn you that you might get bored reading the whole thing.
    JC,
    http://www.tractorbynet.com/forums/n...esting-my.html
    Additional info.
    http://www.tractorbynet.com/forums/n...-my-first.html
    Ford 1700, 2wd.
  7. #7
    Gold Member
    Join Date
    Sep 2008
    Posts
    336
    Manvel Texas
    Ford 1700 2cyl, Ford 1600 2cyl Massey 135 3cyl gas
    Howdy fire, glad to see yet another 1700 owner. Dont have a FEL on mine either, but as jc has mentioned, the adjustment probably needs to be checked along with replacing the lift piston seal. And as always, if you have any pictures of your baby, please post them. Thanks! TB
  8. #8
    Join Date
    Feb 2005
    Posts
    5,645
    Central CT
    J.D. 4310 E-hydro
    Quote Originally Posted by JC-jetro View Post
    John,
    JC,
    Additional info.
    Thanks again JC, that "Testing my patience" thread looks like it would be very helpful if I ever stop procrastinating and change that seal and make necessary adjustments.
    1700 came in handy yesterday pulling tow behind boom lift, the thing weighs over 6000 lbs. It tows fine on the road but is very long so it would be difficult to move around the yard with a truck. the added benefit was when coupled to truck you must unhitch it to raise and level it with the outriggers, with the free floating 3pt no need to unhitch it, makes it much more portable
    JB.
    Attached Thumbnails Attached Thumbnails Ford Hydraulics on a 1700-dscn3593.jpg   Ford Hydraulics on a 1700-dscn3597.jpg   Ford Hydraulics on a 1700-dscn3603.jpg
  9. #9
    Join Date
    Jul 2006
    Posts
    2,850
    Kansas
    Wow John,
    it's way up there in the middle picture. I'm glad you got good outriggers there. I bet you it's shaky up there. I'm glad your putting your 1700 to good use all the time. Great pics.
    JC
    Ford 1700, 2wd.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
