| | #1 (permalink) |
| Elite Member Join Date: Apr 2000 Location: Shingle Springs California
| Looking at tractors; a couple New Hollands have caught my eye. Would a TC30/33/35 or 1510/1520 fit my 7000lb trailer? It is only 16'; those might get a little long. Wondering about weight though. One place has some 1510 and 1520 harvest returns.
__________________ RobertN in Shingle Springs Calif |
| | #3 (permalink) |
| Bronze Member Join Date: Mar 2001 Location: Eastern West Virginia
| I have a TC33D with Loader and Backhoe w/subframe and it fit on my 7000lb GVW car carrier trailer. It fit fine with the backhoe swung to the side. Jay
__________________ Jay White |
| | #4 (permalink) |
| Bronze Member Join Date: Sep 2002 Location: North East NY
| I too have a TC33D with a loader and backhoe sub frame mount and it easily fits on my 16 beaver tail 10,000lb GVW equipment trailer. I would think yours should fit also. |
| | #5 (permalink) |
| Super Star Member Join Date: Feb 2001 Location: Texas - Wise County - Sunset
| Robert, the bare TC35 without a loader or filled tires will weigh around 3350 lb. The loader will add another 1100 lb. The addition of a boxblade puts you at the limit of a 7000 lb trailer. Here is a picture of my TC45D when I took delivery. My trailer is 18' long. I've hauled mine with a 5' cutter on the rear and it hangs off the trailer. I think the TC35 and loader would fit just fine on a 16' trailer, but anything much more than a boxblade in the rear will make it too long and too heavy. If the rear tires are loaded, you'll be overweight without the boxblade. EDIT: My comments relate to the Class III TC35. The Class II tractors will be lighter and shorter. I don't have definitive info for them.
__________________ Jim |
| | #6 (permalink) |
| Thanks! I am going to look at a 1520 today. My other tractor still has not sold though; can't buy yet, but still can do some research.
| | #7 (permalink) | |
| Veteran Member Join Date: Feb 2004 Location: NorCal
| Quote:
seen classes referred to in any of my printed NH spec sheets. One thing IS clear, however: The TC35 is similar in weight to the TC40 and TC45, while the TC33 is about 800 lb lighter. Not in the same "class". (I am always on the lookout for a TC35 project.)
__________________ See my TBN projects at: http://mysite.verizon.net/resyfcgt/ Kubota B21 rebuild 1 cy FEL bucket custom b/h thumb custom b/h subframe Diesel fuel dispenser Bucket dentistry custom hydraulic b/h thumb adapting a 4-in-1 bkt to my Kioti JD 4300 rebuild (new!) | |
| | #8 (permalink) | |
| Quote:
![]() EDIT: I just went to NH's new site. In the Boomer tractors, the numbers are : 1xxx 2xxx 3xxx 4xxx Those numbers correspond to the previous "class" designations. My calling them by the class is probably no longer valid. I should use the new designations when talking about new tractors. Technically, my tractor is a Class III because that's what they called them when I bought mine. However, if you can't find that in reference material, it isn't much use.
__________________ Jim Last edited by jinman; 07-01-2009 at 05:09 PM. | |
| | #9 (permalink) | |
| Quote:
Ag Expo was not clear to me at all. Anyway, thx for the clarification. Don't see many of these blue machines around here.....
| | #10 (permalink) |
| Member Join Date: Jun 2006 Location: Tennessee
| I have a TC 34 which is a class II (same as TC33) that I haul on a 16 foot tandem axle trailer, rated at 7000 lbs. With the FEL bucket resting flat on the trailer floor the rear wheels are parked in the space between the two axles. There would be room for a rear or box blade behind tractor but if you had a bush hog mounted it would overhang the rear of the trailer probably by about 3 feet. As far as weight the trailer easily carries my tractor (tractor, FEL and loaded rear tires), probably about 4000 lbs. I have a 4 foot loading ramp made from 2x2 tubing that makes it real handy too load. As a suggestion I put a 3 ton jack stand under rear edge of trailer when I load and unload tractor. This keeps the rear wheels of my Dodge 1500 firmly on the ground. |
| Thread Tools | |
| Display Modes | |
| Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com |
| Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks. |
