Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Aug 2009
    Posts
    2
    Default 07' TC40 starting problem
    Yesterday after cutting for about 4 hrs., I killed the tractor for about 10 minutes. When i tried to start it again it made a clicking sound - a relay clicked in the start mode and it sounded like the solenoid clicked when I released to the run mode. After repeating several times, the PTO light came on and the starter wouldn't do anything. I checked the fuses(couldn't find but 2) and removed and replaced the relays. I functioned all the levers to check the safety switches and bypassed the seat switch. No luck. I also cleaned the battery terminals. After awhile the PTO light went off and the tractor cranked as normal. Today it cranked normally a few times but then once again refused to crank. After trying a few times I just held the start switch to try to function some levers, after about 5 seconds the PTO light came on again so I switched everything off. After waiting about 10 minutes I heard a relay click and when I tried to crank the PTO light was off but the tractor still would not crank. after trying a few times and the PTO light came on I left the key in the run position and after 10 minutes the PTO light went off and the tractor cranked as normal. Anybody have any ideas?
  2. #2
    Super Star Member jinman's Avatar
    Join Date
    Feb 2001
    Posts
    18,750
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Default Re: 07' TC40 starting problem
    Yes, this is a combination of both starting problems that are common on this model of tractor. The starter solenoid is not engaging the starter motor properly. It's sticking for some reason. As you try to restart, the PTO light comes on because the operator safety system circuit breaker pops. It is a self-resetting thermal circuit breaker, so after awhile, it resets. After you repeat trying to start, the solenoid finally becomes unstuck and makes the starter work.
    When the starter acts up on my older tractor, I normally give it a good rap and it starts working again. If my tractor was in warranty, I'd talk to my dealer about a replacement, but that may not be an option with you. It's a frustrating problem when it happens, but thankfully on my tractor and many others, it doesn't happen often. If you search this forum, you will find lots of discussion about this problem.
    Jim
  3. #3
    New Member
    Join Date
    Aug 2009
    Posts
    2
    Thanks alot for the reply! It all makes sense now. I had thought it was the solenoid acting up but couldn't figure out why the PTO light was coming on. Guess I'll have to tear into the starter and see if I can fix it. For future reference, is there any way to reset the thermal circuit breaker so one doesn't have to wait 10 minutes to try to restart?
  4. #4
    Join Date
    Feb 2001
    Posts
    18,750
    My thermal CB resets within a matter of seconds (probably 10 to 15 sec). I don't know the specs of your CB, but if you replace it with another, there is a good chance it will be one that resets much quicker. 10 minutes just seems very excessive to me.
    Jim
  5. #5
    Join Date
    Sep 2006
    Posts
    57
    It is disturbing to not know for your your tractor will start or just click if you shut it off. I put up with that for some time and then installed the relay mentioned by steveinmd and perhaps others on this site. It has been over a year and it has not failed so far. Seems worth the effort and small expense involved.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
