HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > New Holland/Ford > New Holland Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-03-2009, 12:03 PM   #1 (permalink)
New Member
Default 1975 ford 3550 where to add the hyd. fluid
I just bought a 1975 Ford 3550 ind. where do you add and check the hyd.fluid for the hoe and fel ?
Chuck
chuck1764 is offline   Reply With Quote
Old 11-04-2009, 08:22 PM   #2 (permalink)
Gold Member
Default Re: 1975 ford 3550 where to add the hyd. fluid
If you can post a couple of pictures it would help my memory on that model, both sides would help. That one originally had a two piece loader frame, RH & LH, with a crossover pipe connecting the two. They served as the hydraulic reservoir for both the loader and the backhoe. The filler was located on the left loader post. Later, if I remember correctly, the filler was moved under the radiator shell with access at the top. Hope this helps some.
__________________
The Opti-Mist
Opti-Mist is offline   Reply With Quote
Old 11-15-2009, 06:40 PM   #3 (permalink)
Member
Not sure if yours is the same arrangement as my 6000 but the location of the hydraulic filler had me puzzled for a while. It was finally identified as a common filler for the power steering located under the left side of the engine cover just behind the radiator and in front of the air intake oil bath - see picture - the filler is in the top left corner.
Cheers
Alan
Aussiebushman is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.15329 seconds with 9 queries
