Results 1 to 7 of 7
  1. #1
    Silver Member captjack's Avatar
    Join Date
    Jul 2009
    Posts
    132
    Eastern Shore,MD
    jd 5400
    Default 2420 left rear wheel fell off
    I am asking this for a friend, he was moving snow with his new 2420 and the left rear wheel fell off the machine. When he called the dealer he found out that this has happened to another tractor in the area because they had to order the parts to fix it. This is a new tractor few very few hours on it - the tech came and fixed the wheel and checked the other ones which were all tight.
    So ............. has anyone else had this happen ?
    [FONT="Comic Sans MS"]JD 5400 W/LOADER
    A bunch of stuff to hook to it
  2. #2
    Veteran Member The Haymaker's Avatar
    Join Date
    Jul 2009
    Posts
    1,297
    Benton, Maine
    2008 T2220
    Default Re: 2420 left rear wheel fell off
    Sounds to me like whoever is doing the setup at the dealer needs to be pulled aside......
    "Freedom is never more than one generation from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same, or one day we will spend our sunset years telling our children and our children's children what it was once like in the United States where men were free."
  3. #3
    Join Date
    Jul 2009
    Posts
    132
    Eastern Shore,MD
    jd 5400
    I have some more info on this ........... There are now three tractors in thr area that this has happened to. The one that my friends owns had rear remotes installed. The left rear wheel would have had to come off to install the remotes.
    Our theory is that the tech torqued the wheel to the wrong specs. It is troubling that this has happened to three tractors so far. What we do not know is if they all had remotes installed or if they were all purchased from the same dealer. The dealer fixing my friends tractor is not the dealer that her purchased it from.
    More info when i get it.
  4. #4
    Veteran Member joes_427_vette's Avatar
    Join Date
    Aug 2004
    Posts
    1,243
    Midwest
    New Holland TC 55 DA, 4110 John Deere, HT 20 Bolens, 1456 Bolens
    I had a right front tire deflate under load. Lack of air pressure was the culpret. The left front only had a few pounds in it also. I quickly checked all of them and the bolt torque. Another person I know had a rear wheel seperate from the hub on a larger Deere. It was not tightened to factory specs, came loose and broke the remaining bolts.
  5. #5
    Super Member
    Join Date
    Aug 2004
    Posts
    6,338
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    Seems lots of folks don't know what torque wrenches were designed to do.
    Oh, I'm guilty sometimes myself.
  6. #6
    Join Date
    Jul 2009
    Posts
    132
    Eastern Shore,MD
    jd 5400
    I always refer to the German manual when i look up torque specs
    Tighten all to "goodentight"
  7. #7
    Bronze Member BondoBuilder's Avatar
    Join Date
    May 2009
    Posts
    67
    Quote Originally Posted by captjack View Post
    Yeah I'd rather it be a bear to get loose, than fall off when I'm trying to get something done.
    1989 Ford 3910•NH 451 Sickle Bar Mower•M&W Wheel Rake•IH 435 Square Baler•NH 331 Manure Spreader•16' Steel Livestock Trailer•16' Bumper Pull Trailer•6' Grader Blade•5' Howse Mower•18' Hayrite Elevator•1999 Cummins Diesel
Similar Threads
  1. TF325FH - locking rear left wheel
    By HughSA in forum Iseki
    Last Post: 02-08-2006, 10:56 PM
  2. MF 1230/Iseki TF325FH - locking rear wheel
    By HughSA in forum Massey Ferguson Owning/Operating
    Last Post: 02-06-2006, 06:28 AM
  3. Rear wheel width with midmower
    By Will in forum Kubota Owning/Operating
    Last Post: 06-19-2001, 03:20 PM
  4. WHEEL FELL OFF!!!
    By LilRhody in forum John Deere Owning/Operating
    Last Post: 03-08-2001, 07:01 AM
  5. HELP..rear wheel breaks off!
    By ejb in forum John Deere Owning/Operating
    Last Post: 06-20-2000, 11:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
