schmism
Super Member
WOOT happy dance
after 3 years of looking, wanting, yearning, putting off projects... has come to an end.
we finnally bit the bullet on a $2900 woods 7500 that i found on CL. (w/ 16" bucket)
but allas My happy dance lasted only a short time. for then it was time to figure out how to hook up my new toy.
so it came with a QA mount for a skidsteer. this is infact just a bolt on plate that is added instead of the standard 3pt hookup or subframe hookup (all 3 options bolt on to the hoe in the same place)
but before i can investigate how to best mod the the attachment i need to get the thing up off the ground to the 9-15" clearance recommended by the manual.
to do that i need to hook up they hydraulics. ya should be easy right? ive got a power beyond port plus 2 rear remotes... how hard can it be right!
grrrrrrrrr
so i have never figured out were the power beyond return is on a TC33D. ive read numerous threads, some suggest the rear fill point on the rear axle, some say there should be a second port on the PB block, some talk about running a hose up to the main FEL distribution block.
well hear are some pics people of a TC33D with 2 rear remotes.
the PB male port on the side of the rear remote pack.
(talk about wrestling that female connector on there )
the 2 rear remotes
the front distribution block for the FEL (no help hear as far as i can tell)
the rear side (side faceing the front of the tractor) of the remote pack/PB port block
for now im off to pick up parts to put a second male end on my hoses (or make a male to male adapter likely so that i can connect the BH to a rear remote and tie the handle forward. But id like to use the PB long term because i expect better performance from the PB by not having to go through a rear remote spool.
grrrrrrrrr
the 2 rear remotes
