Results 1 to 7 of 7
  1. #1
    Join Date
    Sep 2009
    Posts
    58
    Default 1920 - Questions on maintenance?
    New to tractors and implements and am helping a friend with maintenance.
    1. What type/weight oil should be used in a Bush Hog brand mower?
    2. Tractor has 2 drain plugs side by side under engine. Are both of these for the crankcase?
  2. #2
    Super Member
    Join Date
    Apr 2000
    Posts
    6,597
    central New York
    all makes and models
    Default Re: Questions on maintenance?
    I like to know a little more about what I'm working on!
    The Bush hog should take gear oil, 80-90 for most all gear boxes.
  3. #3
    Veteran Member kevinj's Avatar
    Join Date
    Jul 2003
    Posts
    1,382
    West MI
    BX-1860, L3940HSTC, B7500, Farmall M, Farmall 560D
    Quote Originally Posted by 2dawoodz View Post
    You would be best served by getting manuals for the equipment in question.
    Kevin
    BX1860, mower, snowblower - B7500HST, FEL, Bush Hog - Grand L3940 HSTC, FEL, snowblower, 6' Landpride brush hog, 6' King Kutter tiller, Corn Pro 18+5 Fifth Wheel, 1950 Farmall M, Farmall 560D
  4. #4
    Join Date
    Sep 2009
    Posts
    58
    Quote Originally Posted by art View Post
    The tractor is a Ford New Holland 1920 4wd. This equipment belongs to a vet friend that I am trying to help out. I agree he needs to purchase manuals.
  5. #5
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    The BH will take 80W90 Gear Oil.
    As for the tractor go to the NH forum on here and ask the questions on the 1920 to get specific info.
    Chris
  6. #6
    Join Date
    Apr 2009
    Posts
    81
    Central Calif hills & Glide, Or
    Ford 2110, 1920, 1710
    Default Re: 1920 - Questions on maintenance?
    1920 4WD has two motor oil drain plugs. Trans\rearend has two drains. Front axle one drain in center. Final drives one drain each on botton. One drain on power steering. Engine uses motor oil. Everything else Ford 134 or equal.
  7. #7
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    add to that that the motor oil should be a 'c' rated oil probably 15w40 unless you are in either extremes of temps.
    soundguy
Similar Threads
  1. buying used 4110 - a few questions
    By kponds in forum Mahindra Owning/Operating
    Last Post: 05-07-2006, 12:31 PM
  2. Draining trans on 1920 questions...
    By casingbill in forum New Holland Owning/Operating
    Last Post: 03-27-2006, 09:22 PM
  3. TC45 maintenance questions
    By itsmatt in forum New Holland Owning/Operating
    Last Post: 08-08-2005, 09:55 AM
  4. John Deere Warranty
    By Big8 in forum John Deere Buying/Pricing
    Last Post: 04-18-2005, 07:00 AM
  5. BX23 Maintenance Questions
    By CurtisB in forum Kubota Owning/Operating
    Last Post: 03-18-2005, 06:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
