Results 51 to 60 of 173
05-08-2010, 09:42 PM #51Silver Member
- Join Date
- Mar 2010
- Posts
- 113
- Location
- Southern US
- Tractor
- Ford 1500
Re: New to tractors ford 1700 question.
BG.....the first thing you do with the bush-hog is "go after" your wife's shrubs and flower beds out there in the yard. It will make cutting the lawn a lot easier and she will eventually get over it......maybe.
05-08-2010 09:42 PM # ADS
05-09-2010, 12:08 AM #52
Hey BG,
I'm glad things are looking up for you slowly but surely. What do you mean by "inside lever on hyd side"? are you talking about you hyd lift system lever? That lever manipulate the hyd spool valve that controls flow to hyd lift piston or bypasses flow back to the rear reservoir( rear diffy). There is no adjustment to the spool itself, the only thing the spool valve has internally is a feed back mechanism that causes flow bypass when lift arm get to it's max travel.
Pic below Shows the spool valve when you remove the hyd piston. There is no adjustment there that includes the feed back linkage .
pIc below shows the feed back linkage from the inside that ties to the feed back control lever outside. This part is adjustable. I would not mess with it unless you have reason to. basically as the lift arm moves up linkage causes the spool valve to internally bypass the oil back to reservoir.
this is the pic of lift arm, as you see it has a low limit that you can set and a high limit tab. that tab is adjustable and has a notch that lift lever can be locked in place. I move it as high as I can short of where the relief starts reliving and chatter.
Relif mechanism as part of the spool valve and relif spring and seat.
Ford 1700, 2wd.
Kubota MX-4700DT, Gear transmission with LA 884 loader, Q/A and HD bucket.
60" Woods Rotary Cutter, home made (3-pt boom and a Row Hipper) ,King Kutter( 5 ft Tiller,Middle Buster,Single Row Cultivator,Carry-all, 5 ft blade, 6 ft Landscaping Rake ,30" Dirt Scoop and a 4'x4' Drag Harrow)
05-09-2010, 07:56 AM #53Member
- Join Date
- Apr 2010
- Posts
- 35
- Location
- Polk county Florida
- Tractor
- ford 1700
Here is a pic of the lever....the one closest to the seat. Where should i set this one?......Im sure the flower beds wouldnt be a good idea on mothers day....next week however is a different story
05-09-2010, 09:25 AM #54
Hmmm. looks different than any 1700 I have seen. The one on the right is most probably your 3 point lift lever. what happens when you move it with the engine on? does your lift arm move? you see it has a upper limit(adjustable). loosen it, move the handle as far as you can move up till you here relief valve chattering, lower it just a tad just as quits chattering , that's you max lift, tighten the upper limit. The one to the left of is some extra hyd remote or draft control. take a pic of the back of the tractor like the pic below and we might be able to tell. what would happen with you move the left handle up or down? or can you tell?
JC,
Ford 1700, 2wd.
05-09-2010, 11:22 AM #55Gold Member
- Join Date
- Sep 2008
- Posts
- 428
I don't have that lever on my 1700 either so I can't help on that part but for a new user of a brush hog, if you haven't brush-hogged before I can give you some tips. Run tractor at least 2000 rpm and up to the recommended 2400 rpm. Engage PTO while stopped and with clutch in. Select gear for type of cutting you will be doing. I usually brush-hog between 2-3 and 3-1 gears, heavy brush could require a lower setting. When mowing be ready to act quick when the machine boggs down in heavy stuff. Pushing in the clutch will stop power to the PTO so quick action may be required to keep from stalling the tractor. The second hand on the 3 pt lift lever if you hit a stump or other obsticle lift the brush-hog to clear to prevent stalling. (You may have to do both at the same time) Keep brush-hog level, both side to side and front to back. Experiance will teach you most of the rest you need to know.
05-09-2010, 08:46 PM #56Veteran Member
- Join Date
- Jul 2005
- Posts
- 1,329
- Location
- W.Mass
- Tractor
- 1993 NH 2120 (the best), 1974 MF 135 (sold, but solid), 1947 Farmall A (bought, sold, bought back, sold again), 1956 MH50 lbt (sold, in 1980, darn it)
And start the hog lifted at low rpm, then bump rpm up to operating speed. Saves the clutches and gearboxes from shock load. Watch when turning cause the hog swings wide. You'll get it soon enough.
Jim"Anything worth doing is worth doing slowly" Mae West
05-09-2010, 10:04 PM #57Member
- Join Date
- Apr 2010
- Posts
- 35
- Location
- Tractor
- ford 1700
Ok i took a couple of pics so hopefully that will help out... i dont see any kind of upper limit adjustment on mine? Thanks for all the tips on the hogging..ill use them all.
The outside lever moves my 3point up and down.. not sure if the inside is doing anything that i can tell.
05-09-2010, 10:51 PM #58
Although I have not seen draft control for 1700, yours appear to be one. The top link bracket is different. draft control maintain a constant depth for ground engaging application like plowing. Can you take a picture where it shows the linkage from smaller lever and how it attaches to control valve or lift arm. I don't see any hydraulic remote(connection ) in the back. do you have any hydraulic connection in front or middle of the tractor.
I hope guys with draft control experience chime in to corroborate or discredit what I just said.
JC,Ford 1700, 2wd.
05-10-2010, 04:46 AM #59Veteran Member
- Join Date
- Feb 2005
- Posts
- 1,770
I can attest to the 1700 having a draft it was optional that year. As I remember not knowing what it was until the dealer told me.
05-10-2010, 05:34 PM #60Member
- Join Date
- Apr 2010
- Posts
- 35
- Location
- Tractor
- ford 1700
No remote hyd connections on it.... i read some of the posts after a search of draft control. So basically this lever is used to set the lowest height that i want it to lower down to? So when im running the hog i should set it and then just use the main lever to raise it if i run over something big like a log or so? JC i took some pics of where it connects, sorry it doesnt show much.
Similar Threads
ford 1700
By walton in forum New Holland Buying/PricingReplies: 67Last Post: 05-13-2013, 09:41 AM -
ford 1700 PHD question
By tulenutn2o in forum New Holland Owning/OperatingReplies: 13Last Post: 11-18-2012, 10:02 AM -
What Ford Tractors will a 770 Loader and 758 Backhoe Fit?
By FordGuy62 in forum New Holland Owning/OperatingReplies: 8Last Post: 04-18-2010, 11:12 PM -
Old Tractors - Comparison: Ford 9N vs. Case SC
By Beervangelist in forum Buying/Pricing/ComparisonsReplies: 22Last Post: 03-20-2010, 10:52 AM -
eBay/Craigslist ebay item
By djg in forum YanmarReplies: 53Last Post: 06-24-2005, 08:37 AM
