Results 1 to 3 of 3
05-13-2010, 04:36 PM #1New Member
- Join Date
- May 2010
- Posts
- 1
Ford 1715 starter
I received a Ford 1715 and all the wires to the starter are disconnected and hanging. Can someone provide a close up pic of the starter with all of the cables connected? IE Battery, alt, key switch, etc... Thanks in advance.
05-13-2010, 09:09 PM #2Platinum Member
- Join Date
- Sep 2008
- Posts
- 743
- Location
- Midwest
- Tractor
- n/a
Re: Ford 1715 starter
Try looking at the diagrams on Messicks or Part Spring.
They are great online resources.
05-15-2010, 04:11 PM #3Member
- Join Date
- May 2009
- Posts
- 36
OK, attached is a flat out horrible picture!!!! So..... I'll try to explain. There is a lug and a spade. The lug is about 3/8" threaded for nut and about 3/4 inch long. This is where the battery connects along with any other wires that need a "battery feed". The small spade is the feed from ignition to the solenoid. It is a two stage solenoid, but all of that is internal to the starter.
Hopefully this helps!!!
Audo
Similar Threads
Ford 1715 -- part of real estate deal?
By mikefromnh in forum New Holland Buying/PricingReplies: 8Last Post: 05-05-2010, 11:17 PM -
Oil & Fuel 3600 ford diesel, starter solenoid
By georgia plow boy in forum New Holland Owning/OperatingReplies: 4Last Post: 11-25-2009, 10:34 PM -
solenoid
By Tinkerer in forum General Vintage TractorsReplies: 19Last Post: 02-17-2004, 08:58 AM -
Jump-Starting a Ford 801
By Mrwurm in forum Ford Vintage TractorsReplies: 3Last Post: 12-02-2003, 10:11 PM -
Ford to Ford/New Holland transition ???
By Argee in forum New Holland Owning/OperatingReplies: 6Last Post: 11-29-2003, 03:37 PM
