Results 1 to 10 of 16
09-21-2010, 09:23 AM #1
- Join Date
- Sep 2010
- Posts
- 10
- Tractor
- new-holland 1720
1720 Alternator wiring problem
Anyone have a color-coded wiring diagram for the alternator on a 1720? I discovered I don't have a warning light for the alternator. In my investigation it turns out that 2 wires in the wire bundle within inches of the alternator aren't terminated. A white red striped with brown spots wire that goes back to the light. A white with brown spots (no stripe) that goes to the "L" terminal on the Alternator.
If I connect these, the light works perfect but the tractor won't stop running with the ignition switch off. The reason is that the "L" wire carries a constant 2 volt current when the alternator is spinning. This voltage bleeds back to the fuel stop solenoid and is just enough to keep it from shutting off.
HELP! Thanks
09-21-2010, 10:29 AM #2
Re: 1720 Alternator wiring problem
Ford 1700, 2wd.
Kubota MX-4700DT, Gear transmission with LA 884 loader, Q/A and HD bucket.
60" Woods Rotary Cutter, home made (3-pt boom and a Row Hipper) ,King Kutter( 5 ft Tiller,Middle Buster,Single Row Cultivator,Carry-all, 5 ft blade, 6 ft Landscaping Rake ,30" Dirt Scoop and a 4'x4' Drag Harrow)
09-21-2010, 10:49 AM #3
R.I.P.
- Join Date
- Feb 2001
- Posts
- 21,014
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
JC, it appears from your diagram that you have an external VR and the OP has a VR internally in his alternator from his description of the wires. Don't know. . .
Jim
09-21-2010, 11:25 AM #4
- Join Date
- Sep 2010
- Posts
- 10
- Tractor
- new-holland 1720
Thanks to both of you. Didn't know this is the quick way to reply. Yes I have an internal VR. Can anyone say whether or not the 'L' terminal should be putting out the 2 volts constantly? Thanks
09-21-2010, 11:41 AM #5
R.I.P.
- Join Date
- Feb 2001
- Posts
- 21,014
- Location
- Tractor
Jnhelton, I answered your PM. Without the diagram, I think there is an isolation diode missing, bypassed, or shorted. My tractor has an isolation diode to keep any postive voltage from feeding back and powering the bus through the light.
Jim
09-21-2010, 12:09 PM #6
Ford 1700, 2wd.
09-21-2010, 12:14 PM #7
R.I.P.
- Join Date
- Feb 2001
- Posts
- 21,014
- Location
- Tractor
Well your diagram does show the light "L" lead from the external regulator. It's wired pretty much like mine and others with internal regulators, but I have an isolation diode after the light between it and the bus. I'm not sure of the symbology on your diagram, but I didn't see anything like that.
Jim
09-21-2010, 02:39 PM #8
- Join Date
- Sep 2010
- Posts
- 10
- Tractor
- new-holland 1720
I'm betting you're right jinman. This isolation diode is in the internal IC circuit right? I think the original owner cut the wire rather than fix it!?
09-21-2010, 04:54 PM #9
R.I.P.
- Join Date
- Feb 2001
- Posts
- 21,014
- Location
- Tractor
I think you could put one inline. Just make sure the negative end is turned toward the alternator's "L" output. That way it will allow normal current to illuminate the light and isolate the circuit when the key is turned off.
EDIT: I just changed the word above to "negative." I don't know what made me type positive the first time. Must be old age.Jim
09-22-2010, 07:33 AM #10
- Join Date
- Aug 2010
- Posts
- 332
Originally Posted by jnhelton
Similar Threads
B2400 starting problem finally solved
By victor43 in forum Kubota Owning/OperatingReplies: 60Last Post: 05-31-2017, 04:45 PM -
Boomer Problems
By froggy in forum New Holland Owning/OperatingReplies: 29Last Post: 03-21-2014, 02:29 PM -
Power Steering Problem Not Solved
By Alan L. in forum Kubota Owning/OperatingReplies: 87Last Post: 03-31-2011, 06:35 PM -
Cub 1720 starter problem
By jim burkett in forum Cub Cadet TractorsReplies: 2Last Post: 11-21-2007, 07:42 PM -
New BX 2200 Throttle Problem
By Anonymous Poster in forum Kubota Owning/OperatingReplies: 3Last Post: 06-02-2003, 10:23 PM
