Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Oct 2010
    Posts
    1
    new holland 1630
    Default 1930 will not rev
    I just picked up a 1630 that was not running. I got it running today but it will only idle. It is not the shut off solenoid I can remove that and use a magnetic pick up tool to move the rod on the pump to overcome the governor and it will rev some. Is there a governor adjustment or is something stuck in the governor? Any help would be greatly appreicated .
  2. #2
    New Member rancherogt's Avatar
    Join Date
    Aug 2009
    Posts
    15
    mid michigan
    Worlds most powerful Ford 1210 FWD hydro, 25hp dynoed off the PTO, 1980 Sears GT14 with 10hp diesel power plant
    Default Re: 1930 will not rev
    Sounds like a fuel volume problem change your fuel filter first under the tank before looking at any injection pump problems.
  3. #3
    Join Date
    Oct 2005
    Posts
    1,437
    N. E. Ohio
    tc- 29d
    throttle cable working?
    dqdave1; tc-29D; woods 7500 bh; 7308 fel, land pride tiller, land pride rake, gill pulverizer, 60"mmm. , bucket forks , MZ16H
Similar Threads
  1. Run out of diesel in Rev. C
    By Gadgetnut in forum Toolcat
    Last Post: 06-07-2014, 07:31 PM
  2. 545d is slow to rev up!
    By buckles in forum Construction Equipment
    Last Post: 07-29-2010, 01:41 PM
  3. 2 Cycle Will Not Rev Up
    By davey4000 in forum General Lawn & Garden
    Last Post: 11-17-2009, 04:50 PM
  4. Ford 4000 rev counter
    By 08mckerp in forum Parts/Repairs
    Last Post: 04-06-2009, 11:24 AM
  5. Starter will turn motor only one rev.
    By Kruzer in forum Parts/Repairs
    Last Post: 08-10-2008, 05:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
