Results 1 to 8 of 8
  1. #1
    Silver Member linrick1's Avatar
    Join Date
    Aug 2008
    Posts
    141
    Ashburnham, Mass.
    Ford 1900, Steiner 430
    Default Hyd. oil heater for 1900
    Anyone ever installed a 110v immersion heater in their trans/rear end to keep the hyd. oil from freezing? In keeping with my policy of "everything I touch will cease to operate", now the hydros are froze on our tractor. This has happened to me before, and I usually just thaw it out with our space heater and a tarp and off I go.....but my space heater croaked two days ago and despite going right through the thing, still will not work.......tarps probably broke too, touched that the other day.......Rick
    Attached Thumbnails Attached Thumbnails Hyd. oil heater for 1900-12-21-08-20026-jpg
    Ford 1900 FWD with 771 FEL
    Woods 750 BH
    Steiner 430, 60" deck, 48" snow blower, cab
    CTI Forks
    7.5' Fisher P/A plow
    Timberwolf TW-P1 Splitter
    Stihl 026 Pro/036 Pro/HT101/BR 340
    Honda Foreman ES
    Lincoln Weldanpower AC 225
    Simplicity 870 28" Snowblower
    Meteor 66" Snowblower
    Gravely LI/30" Brush Deck/Sulky
    Gravely 5665/50" Finish Deck/Steering Sulky
  2. #2
    Join Date
    Dec 2008
    Posts
    111
    Default Re: Hyd. oil heater for 1900
    I've been having that problem lately and have to wait for it to warm up a bit before I can remedy it. In the meantime, I put a magnetic heater that I had on the side of the reservoir. Warmed the case enough that the snow on top of it melted but still no go with the hydraulics. Either the filters plugged on mine or it's still froze up somewhere else in the system. I'm running the same loader as you and also have a blade out front that uses hydraulics.
  3. #3
    Elite Member JC-jetro's Avatar
    Join Date
    Jul 2006
    Posts
    3,294
    Kansas
    Ford 1700, Kubota MX-4700
    Quote Originally Posted by linrick1 View Post
    The problem is the moisture in the oil. I think magnetic heater is better than directly cooking the oil. the problem is the heat might not get to the orifices of the spool valve and the rest of hyd system. I might use a blow drier or heat gun to gently warm spool valve and the lift piston head along with transmission case warming.
    JC,
    Ford 1700, 2wd.
    Kubota MX-4700DT, Gear transmission with LA 884 loader, Q/A and HD bucket.
    60" Woods Rotary Cutter, home made (3-pt boom and a Row Hipper) ,King Kutter( 5 ft Tiller,Middle Buster,Single Row Cultivator,Carry-all, 5 ft blade, 6 ft Landscaping Rake ,30" Dirt Scoop and a 4'x4' Drag Harrow)
  4. #4
    Join Date
    Dec 2008
    Posts
    111
    A heat gun only goes so far when it's -25c and the winds blowing. That's why in my case, I'm waiting to do and oil change and filter cleaning. It's going to warm up any day according to the weather man. And if you can't trust the weather man.
    Rick, how's that blade on the bucket work for ya?
  5. #5
    Join Date
    Feb 2001
    Posts
    1,447
    South-central Michigan
    New Holland TC40D
    I have not, but I have used magnetic heaters, and they work just fine.
  6. #6
    Elite Member Jerry/MT's Avatar
    Join Date
    Feb 2008
    Posts
    2,608
    Western Montana
    New Holland TD95D, Ford 4610 & Kubota M4500
    The space heater is probably your best bet for getting it thawed out. And when you do, before your operate, open the drain and see if you can drain the water off. You'll spill some fluid but you may get a good bit of water out.
  7. #7
    Veteran Member Hooked_on_HP's Avatar
    Join Date
    Dec 2005
    Posts
    2,050
    Coal City IL
    Ford 1900 FWD Kubota F2100E
    With todays oils the water will not seperate. It becomes emulisified with the oil. The only way to remove the moisture is to change the oil.
    Bill
  8. #8
    Join Date
    Aug 2008
    Posts
    141
    Ashburnham, Mass.
    Thanks for the help eveyone, this morning I crawled under the old girl with the rosebud on my torch and warmed up the area around the suction filter. It didnt take to awful long, maybe a half hour, and the hydraulics began to resume working. A little jerky at first, but smoothed right out and worked as advertised for the 3 something hours I plowed. I hadnt thought of how poorly oil transfers heat but I understand why a magnetic heater would be the way to go so I'll give that a shot. The plow works really well, but at some point I want to build a mount that will bring the blade closer to the front of the tractor 'cause that thing hangs way out there. As for the space heater method, I agree entirely - but again, my space heater has picked this unfortunate time to expire...and has thwarted my every attempt to repair it. Ill fix that too....thanks again ,Rick
    Woods 750 BH
    CTI Forks
    Honda Foreman ES
Similar Threads
  1. Deere oil vs. amsoil
    By spruce Deere in forum Oil, Fuel & Lubricants
    Last Post: 04-23-2010, 08:36 PM
  2. Oil Failure
    By TPS in forum Oil, Fuel & Lubricants
    Last Post: 07-01-2009, 12:52 PM
  3. No Oil Pressure
    By Jim518N381813 in forum General Vintage Tractors
    Last Post: 04-20-2009, 10:28 AM
  4. Burning waste oil in a kerosene forced air heater?
    By KYErik in forum Build-It Yourself
    Last Post: 01-26-2008, 01:49 AM
  5. tc25d cab heater hookup
    By kjwpop in forum New Holland Owning/Operating
    Last Post: 01-02-2006, 08:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
