pharmvet
- Joined
- Sep 28, 2008
- Messages
- 535
- Location
- North East TX
- Tractor
- Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I have a 7710 tractor with an upper and lower fuel tank. As I understand it, fuel feeds to the engine always from the lower tank. The upper tank empties via gravity into the lower tank as fuel is consumed. My tractor has a toggle switch on the dash that is used to check the fuel levels in each tank. #1 on top which apparently corresponds to the upper tank, and #2 on the bottom which apparently corresponds to the lower tank.
The upper tank reading (#1) has always worked since I bought the tractor, the lower tank reading (#2) has never worked since I bought the tractor.
The other day I had to have the lower tank dropped to fix a leaking return fuel line. I figured it would be the perfect time to replace the lower tank sending unit, which I assumed was the problem since the fuel gauge was correct for the upper tank.
Now I have a new sending unit in the lower tank and my #2 fuel reading still does not work. To add some confusion, I carried a sending unit to the dealer that did the installation (I had purchased sending unit from local dealer) and was told it was incorrect and they had to order another that matched the one they removed. They said it was hard to find and they had to use the part # off of the old one. When I returned the new sending unit to the dealer I bought it from, they found it hard to believe it was not the correct one.
QUESTION: Could the problem be in the toggle switch even though it registers correctly on the upper tank? OR
Is the problem more likely in the sending unit, and possibly someone had used an incorrect sending unit in the past and I just replaced it with an identical incorrect sending unit?
