Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Default 1969 3000 ford tractor
    I HAVE 1969 FORD 3000 TRACTOR ITS HAS A SIMS INJ PUMP IT LEAKS FUEL OUT THE OVER FLOW AT IDLE. I CHANGED OIL IN PUMP DID NOT HELP ANYONE KNOW HOW TO FIX,OTHER THAN REBUILDING PUMP
  2. #2
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,584
    Lincoln County, NC need new avatar!
    Just a Scag
    Default Re: 1969 3000 ford tractor
    There is no quick fix. A pump rebuild is in order. Until then, drain off the fuel/oil mix as soon as you see it overflowing and refill with fresh oil to the proper level. No need of damaging the pump's cam and followers more than necessary.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
