Turbys_1700
Elite Member
I've read a lot of information during a search on ignition issues with the switch on some of the NH compact tractors. My 1720 currently has an intermittent issue with the ignition switch. So far, I have been able to get the tractor to crank.
First issue: The plastic ring that holds the switch in place is broken and the switch turns inside the ring holder while you try to start it. Last week I unbolted the sheet metal and was able to hold the switch with my hand and turn the key. The tractor did start up eventually but this was after repeated attempts to fire her up.
Issue #2: Sometimes, turning the key on will result in nothing but if you hold the key in the on poistion she will eventually fire up.
Does this sound like a new ignition switch is needed or is this a grounding issue?
Many thanks for any input.
