Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Member
    Join Date
    Feb 2011
    Posts
    43
    Ford 3000
    Default Ford 3000
    I have a couple of questions first off my radiator has a small leak so I'm taking it out to get rebuilt but as I took of my grill there's 2 brackets look to be mounting brackets anyone know what this is for?
    Next is it's a oil bath air cleaner capacity as I read in the specifications Is 1.9pt.
    But the question is of what kind of oil?
    And how would you even clean this filter it looks to be dirty at the bottom I took off is gummed up hardly any oil in it.
    And my radiator was just setting in there should there be some kind of mounting brackets?
    Thanks for you'll help I'm trying to restore this tractor a little at a time but it's time to start making hay as will so I'm trying to use the tractor to rack and cut with as well! And I attached a picture of the 2 brackets
    Attached Thumbnails Attached Thumbnails Ford 3000-image-614406500-png
  2. #2
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: Ford 3000
    so far i see a pic of the radiator and front bolster..
    rad is secured from the bottom
    oil in oil bath claner is the same you put in the crankcase.
    remove the breather and take the media out and clean in solvent of choice..or imerse in a bucket of diesel and agitate..
    clean the cup.. oil the media and fill the cup to the line.. reinstall.
    soundguy
  3. #3
    Member
    Join Date
    Feb 2011
    Posts
    43
    Ford 3000
    Default
    Heres another picture its I'm only guessing it maybe light brackets?
    Attached Thumbnails Attached Thumbnails Ford 3000-image-4281306271-png
  4. #4
    Member
    Join Date
    Feb 2011
    Posts
    43
    Ford 3000
    Default
    Here's a few more
    Attached Thumbnails Attached Thumbnails Ford 3000-image-1074444856-png   Ford 3000-image-969790789-png
  5. #5
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    my 3000 doesn't have those. it's sure not for the lamps.. here's a pic of the front bolster..
    Attached Thumbnails Attached Thumbnails Ford 3000-3000fraxle-gif
  6. #6
    Veteran Member whodat526's Avatar
    Join Date
    Apr 2010
    Posts
    1,529
    deridder louisiana
    fords
    yes that is headling brackets which means u must have a english built tractor with a A or B serial number
  7. #7
    Member
    Join Date
    Feb 2011
    Posts
    43
    Ford 3000
    Default
    Some one might of changed some parts I'm guessing cause the ser. # is B*831166*
  8. #8
    Join Date
    Apr 2010
    Posts
    1,529
    deridder louisiana
    fords
    Quote Originally Posted by Donovan Caro View Post
    yea that tractor was a imported tractor it was made in basilton england
  9. #9
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    well that answers part of it.. a basildon sn.
    I bet he's got a parking brake on the left too
  10. #10
    Member
    Join Date
    Feb 2011
    Posts
    43
    Ford 3000
    Default
    Maybe they should have one on the left but there's non on the tractor at all. What I was getting at with the brackets and parts changed is that the grill had no hole for lights.
    Thanks for all you'll help
Similar Threads
  1. Ford 3000 Fluid types
    By Allemay in forum New Holland Owning/Operating
    Last Post: 05-14-2018, 05:37 PM
  2. Kubota L35 compared to Ford 3000
    By clsmith in forum Kubota Owning/Operating
    Last Post: 02-21-2012, 06:14 AM
  3. Ford & IH finalize diesel divorce
    By Builder in forum Trailers & Transportation
    Last Post: 01-19-2009, 09:17 PM
  4. Parts Box Attached to Ford 3000
    By jlanglois in forum Attachments
    Last Post: 08-04-2003, 11:49 PM
  5. Ford 3000
    By Anonymous Poster in forum New Holland Owning/Operating
    Last Post: 10-06-2001, 11:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
