Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Jun 2010
    Posts
    11
    Default Replacing lower lift arm on TC 40.
    Any tricks to getting the pin out that holds the lift arm at the axle? After taking the bolt out from the keeper tab I tried sliding the pin out, but no luck. Prying on the tab just left it bent. Any ideas?
  2. #2
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Default Re: Replacing lower lift arm on TC 40.
    Rather than prying out on the tab, try tapping it radially around the axis so the pin spins in the hole. Once the pin twists, it will loosen and should come out. I removed mine when my tractor was fairly new and they popped right out.
    Attached Thumbnails Attached Thumbnails Replacing lower lift arm on TC 40.-lowerlinkpin-jpg
    Jim
  3. #3
    Gold Member MiserableOldFart's Avatar
    Join Date
    Jun 2006
    Posts
    307
    Delaware County Catskills NY
    NH TC26DA, Kubota GR2120
    Don't mean to insult with the totally freaking obvious, but did you try some penetrating oil? If so, please forgive this post.. I know it's like the manual that says when your computer doesn't work to check to see if it's plugged in..
    New Holland TC 26 DA + FEL
    Kubota GR2120
    Bush Hog RDTH 60
    Woods 6ft. back blade
    Countyline Post Hole Digger
    Allied Snow Blower
  4. #4
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    M-O-F, I love your avatar. Anybody who wears black socks with shorts and suspenders is okay in my book. I'm serious. . . you look like you know how to enjoy yourself and "to heck" with everyone else.
    Jim
  5. #5
    Join Date
    Feb 2001
    Posts
    1,447
    South-central Michigan
    New Holland TC40D
    Quote Originally Posted by ksterling View Post
    Rather than prying, can you get between the tip of the pin and the transmission case to the inside and try pushing it out with a large pry bar or similar sturdy piece of steel?
  6. #6
    Join Date
    Sep 2009
    Posts
    87
    I've knocked many of these loose over the last 15 years. Give it a small whack with a 2lb. balpeen hammer,as if you were trying to pound it in further. It should pop loose. If not,try soaking with penetrating oil over night and re-apply hammer method. My tool of choice.
  7. #7
    Join Date
    Jun 2006
    Posts
    307
    Thanks, Jinman. That get-up and photo was for my ex-coworkers. I am retired postal and that's my old uniform the way I used to wear it (no hardhat or suspenders) on the job, and giving what I used to call the "postal salute."
    Kubota GR2120
    Bush Hog RDTH 60
    Allied Snow Blower
  8. #8
    New Member
    Join Date
    Jun 2010
    Posts
    11
    Thanks for all the ideas, most of them I had tried, especially the penetrating oil. I took the tractor to my trusted mechanic who tried all the previously mentioned ideas with no success. He even went as far as removing the wheel and welding a nut on the end of the pin to try and move it. In the end, it had to be cut out and a new pin put in.
Similar Threads
  1. broken lift arm shaft
    By bsstreet in forum New Holland Owning/Operating
    Last Post: 05-04-2011, 11:07 AM
  2. Replies: 0
    Last Post: 12-02-2009, 02:22 AM
  3. Broken 3 point lift arm
    By longrange2 in forum Yanmar
    Last Post: 06-05-2007, 02:40 AM
  4. Snapped lift arm
    By Makers_Mark in forum Mahindra Owning/Operating
    Last Post: 03-14-2007, 02:18 PM
  5. yanmar 1500, 3 pt. lift will not lower
    By spiter23 in forum Yanmar
    Last Post: 08-23-2003, 06:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
