1720 aux hyd?
   / 1720 aux hyd? #1
Anonymous Poster
I'm looking at a 1720 with a front end loader. Walking around it, I see there is no hyd port(s) on the back of it.
Can there be? Is that an option, or an add-on kit (spendy?)?
If the loader is removed, can the twin quick-couple ports for the loader be plumbed to the back with some hoses, & the joystick used to run hyd implements?
I have a farm background, but not real good with hydaulic systems...
--->Paul
   / 1720 aux hyd? #2
A rear hydralic port is a dealer added option on the 1720. I'm not sure the cost, but it has been in the $500 range for my Ford/ New Hollands.Andy
   / 1720 aux hyd? #3
Are you looking for a "controlled" rear hydro port or just one to hook up a backhoe or similar device. For a backhoe, I've seen where they just plumb it with hose from the hydro block, located on the right side of the tractor under/infront of the foot rest, back to the implement. Plumbing in this way would give you no control but provide a supply to a backhoe. If you want control, then the factory kit is a really nice way to go. It taps on to the valving under the seat and provides a control lever in the fender.
