Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    May 2011
    Posts
    2
    Default 1965 Ford 5000
    Last night I was able to identify the model tractor I have through the kindness of a member on this website. It's a 1965 Ford 5000 diesel 8spd.
    A neighbor of mine was nice enough to give me a tractor and I would like to put it to use. I know that I do not want to start it before I change the fluids & filter, but I am unsure of what to use. It seems that the fluids are low and old, plus when it is running the pto is always turning even when it's supposed to be disengaged. It turns very slow when the lever is in the off position, but I think it may be because it needs fluids. Idk?
    I need to know what type of oil and transmission fluid to use, I also need to know what type of filter to put on it. The person who gave it to me didn't seem to be a real stickler for proper fluids and filters, so that is why I am here. I spent most of the day looking for a manual on the tractor, but was unable to find one.
    I would appreciate any help or advice that can be helpful.
    Thanks,
    RC
  2. #2
    Elite Member Jerry/MT's Avatar
    Join Date
    Feb 2008
    Posts
    2,608
    Western Montana
    New Holland TD95D, Ford 4610 & Kubota M4500
    Default Re: 1965 Ford 5000
    Quote Originally Posted by rockagibraltar View Post
    Thanks,
    RC
    You're obviously new to tractors so the best advice I can give you is to get the manuals. Try Tractor, Implement & Equipment Manuals, Books and Videos - Jensales, ebay, or just google "Ford 5000 manuals" etc. and try to get a factory manual not an IT manual. Reprints should be available if the originals are all gone. Get an owners manual as a minimum. It will have all the fluid specs and quantities. Your hydraulic system uses the rear axle for the hydraulic sump and that fluid also lubes the rear axle. It will us Universal Tractor Fluid(UTF) that meets Ford M2C134D specs. Most likely your tranny uses the same fluid but you'll need to verify these fluids requirements with somebody that has the same model tractor.
    If you are going to do your own repairs then get the shop manual and the parts manual. I like the factory manuals be cause they give you systems decriptions that tell you how the tractor is supposed to work and that's helpful when you are troubleshooting.
    As far as the pto turning when it's disconnected, if you have an independent pto that's' most likely due to the clutch plates being warped a little and transmitting a little bit of torque to the shaft. It's not a serious problem.
    A New Holland dealer can get the parts or go to Home page and put in Ford 5000 and it will tell you the Wix filters that are used by your tractor. Take away the first Wix part number and that will be the equivalent NAPA part number. if you have a diesel tractor make sure that your air filter is clean wheher it's an oil bath or a a dual cartridge type. Most oil bath air cleaners have never been well maintained.
  3. #3
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,744
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    yep.. utf fluid ( walmart or TSC or parts store generics ) are fine.. meeting the M2C134 spec is what you want.
    for the engine, 15w40 C rated oil.. or perhaps 10w30 C rated oil if in arctic areas. just be sure it is a C rated ( diesel ) oil.
    spin on oil filter is a 8$ job from the dealer.. i think the # is 86546614, though a fram ph8a, supertech st8a or motorcraft fl1a, or napa 1452 and a 1515 will fit it.. etc..
    soundguy
  4. #4
    Bronze Member HakanTh's Avatar
    Join Date
    Dec 2010
    Posts
    67
    Sweden
    1969 Ford 4000
    Quote Originally Posted by Soundguy View Post
    ...spin on oil filter is a 8$ job from the dealer.. i think the # is 86546614, though a fram ph8a, supertech st8a or motorcraft fl1a, or napa 1452 and a 1515 will fit it.. etc..
    soundguy
    If it is the original cartridge type engine oil filter (a cylindrical container with a hexagonal head screw at the bottom) you need WIX #51279.
    WIX has got a good look up function on their website:
    WIX Filters : Filter Look-Up
  5. #5
    Join Date
    Mar 2002
    Posts
    52,744
    Central florida
    ch14pl if fram, and 1279 if napa.. both are the cartridge style, if that is what it uses..
    soundguy
Similar Threads
  1. Chevy vs Ford Diesel Shootout
    By Stimw in forum Trailers & Transportation
    Last Post: 11-25-2010, 10:09 PM
  2. Ford 5000 and IH 480 disk hyd qd
    By Fred Smith in forum Hydraulics
    Last Post: 08-05-2009, 05:46 PM
  3. Ford 5000 Alternator Conversion
    By El_Gato in forum New Holland Owning/Operating
    Last Post: 01-24-2007, 09:43 AM
  4. ford 5000
    By Soundguy in forum New Holland Buying/Pricing
    Last Post: 10-08-2005, 11:22 AM
  5. Price Check 1965 Ford 3000 Super Dextra price
    By F350 in forum Buying/Pricing/Comparisons
    Last Post: 11-04-2003, 10:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
